Datasheet Texas Instruments LMK04031BISQ/NOPB — Даташит
СерияLMK04031
МодельLMK04031BISQ/NOPB
Малошумящий очиститель тактового джиттера с каскадными схемами ФАПЧ 48-WQFN от -40 до 85
LMK04000 Family Low-Noise Clock Jitter Cleaner with Cascaded PLLs datasheet
PDF, 1.5 Мб, Версия: J, Файл опубликован: 19 сен 2011
Pin48
Package TypeRHS
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY1000
МаркировкаK04031BI
Width (мм)7
Length (мм)7
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Количество входов2
Количество выходов6
Output Frequency(Max)1570 МГц
Output Frequency(Min)0.35 МГц
Output Level2VPECL,LVCMOS,LVDS,LVPECL
Package GroupWQFN
Package Size: mm2:W x L48WQFN: 49 mm2: 7 x 7(WQFN) PKG
RMS Jitter0.115
Special FeaturesInt. xtal oscillator,Manual/auto switch
Supply Voltage(Max)3.45 В
Supply Voltage(Min)3.15 В
VCO Frequency(Max)1570 МГц
VCO Frequency(Min)1430 МГц
  • Evaluation Modules & Boards: LMK04031BEVAL
    Clock Jitter Cleaner With Cascaded PLLs and Integrated 1.5 GHz VCO (LVPECL LVDS LVCMOS Outputs)
  • AN-1950 Silently Powering Low Noise Applications (Rev. A)
    PDF, 10.5 Мб, Версия: A, Файл опубликован: 22 апр 2013
    This application report explains how to implement a low noise switch mode power supply solution. Itintroduces the sources of noise and explain how to minimize them. A big factor in noise generation andpropagation is the printed circuit board layout. Important basics are discussed. Circuit measurementtechniques are also explained to guide a design engineer towards a low noise but efficient so
  • AN-1910 LMK04000 Family Phase Noise Characterization (Rev. A)
    PDF, 5.1 Мб, Версия: A, Файл опубликован: 26 апр 2013
    The purpose of this applications report is to present phase noise and jitter measurements representing the clock outputs of the LMK04000 family of Precision Clock Conditioners, when paired with various voltage controlled oscillators (VCXOs). The intent is to illustrate the relationship between clock output phase noise and VCXO phase noise.
  • AN-1939 Crystal Based Oscillator Design with the LMK04000 Family (Rev. A)
    PDF, 8.2 Мб, Версия: A, Файл опубликован: 26 апр 2013
    This application report for the LMK04000 family of clock conditioners covers the design of an external oscillator circuit using a crystal resonator.
Серия: LMK04031 (3)
  • Semiconductors > Clock and Timing > Clock Jitter Cleaners > Dual / Cascaded PLL
На английском языке: Datasheet Texas Instruments LMK04031BISQ/NOPB
