Оптопары и оптореле Megawin
Datasheet Texas Instruments VCA824IDG4 — Даташит
СерияVCA824
МодельVCA824IDG4
Широкополосный 420 МГц, диапазон регулировки усиления >40 дБ, линейный по В/В усилитель с переменным коэффициентом усиления 14-SOIC от -40 до 85
VCA824 Ultra-Wideband, > 40-dB Gain Adjust Range, Linear in V/V Variable Gain Amplifier datasheet
PDF, 2.2 Мб, Версия: D, Файл опубликован: 5 янв 2016
Pin14
Package TypeD
Package QTY50
МаркировкаVCA824ID
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Acl, min spec gain2 V/V
BW @ Acl710 МГц
Max Gain40 дБ
Количество каналов1
PGA/VGAVGA
Slew Rate(Typ)2500 V/us
Vs(Max)12 В
Vs(Min)8 В
  • Evaluation Modules & Boards: DEM-VCA-MSOP-1A
    DEM-VCA-MSOP-1A
  • Evaluation Modules & Boards: DEM-VCA-SO-1B
    DEM-VCA-SO-1B
  • Evaluation Modules & Boards: TSW7001EVM
    TSW7001 Voltage-Controlled Amplifier Demonstration Kit
  • Tips and tricks for high-speed, high-voltage measurement
    PDF, 584 Кб, Файл опубликован: 28 апр 2015
  • Implementating a Variable-Length Cat5e Cable Equalizer
    PDF, 505 Кб, Файл опубликован: 25 апр 2010
    Unshielded twisted pair (UTP) cables have long been used to transmit data over long distances, starting with telephone line networks. As a result of the relatively low cost, these cables have also been adopted for various uses including video distribution. All UTP cables attenuate the signal over frequency with maximum attenuation at maximum signal frequency. This attenuation will also increase as
  • Analog Applications Journal 2Q 2015
    PDF, 2.5 Мб, Файл опубликован: 28 апр 2015
  • Wireline Data Transmission and Reception
    PDF, 191 Кб, Файл опубликован: 27 янв 2010
    Many types of wires are widely used to transmit data. Specifically, Category 3 and Category 5 (Cat3 and Cat5e, respectively)—also known as unshielded twisted pair or UTP lines—are now recommended for new telephone installations. Coaxial (coax) cables are used to distribute cable television (CATV) signals throughout a home. #12 and #14 American wire gauge (AWG) electric power distribution wire is a
Серия: VCA824 (5)
  • Semiconductors > Amplifiers > Programmable & Variable Gain Amplifiers (PGA/VGA)
На английском языке: Datasheet Texas Instruments VCA824IDG4
