Помощь в переводе проектов на ПЛИС азиатских брендов
Datasheet Texas Instruments TMS320VC5510GGW21 — Даташит
СерияTMS320VC5510
МодельTMS320VC5510GGW21
Процессор цифровых сигналов с фиксированной точкой 240-BGA MICROSTAR
Datasheet
TSP
Pin240
Package TypeGGW
Industry STD TermBGA MICROSTAR
JEDEC CodeS-PBGA-N
Width (мм)15
Length (мм)15
Thickness (мм).9
Pitch (мм).8
Max Height (мм)1.4
RoHSНе совместим
  • OMAP: Enabling Multimedia Applications in 3G Wireless Terminals
    PDF, 211 Кб, Файл опубликован: 1 дек 2000
    This paper describes how the Open Multimedia Applications Platform(tm) software and hardware architecture enables multimedia applications in third-generation (3G) wireless appliances. It provides an overview of OMAP(tm) strategy, concepts, main milestones, and achievements. It also describes OMAP hardware architecture, explains how multimedia applications can benefit from this advanced architectur
  • Using the TMS320VC5509/5510 Enhanced HPI (Rev. A)
    PDF, 458 Кб, Версия: A, Файл опубликован: 19 май 2006
    The enhanced host port interface (EHPI) on the TMS320VC5509 and TMS320VC5510 DSPs provides a 16-bit port through which a host device may access the internal and external memory space of the DSP. The flexibility of the EHPI interface allows various host devices to interface with the DSP using minimal or no external interface logic. This document describes various possible EHPI configurations and ex
  • Using the Power Scaling Library (Rev. A)
    PDF, 402 Кб, Версия: A, Файл опубликован: 30 сен 2004
    Power consumption is a key concern for embedded system developers. By developing low-power solutions, developers can deliver products that have longer battery life. One technique that can be used to save power is frequency and voltage scaling of the processor.Since the power consumption of a DSP is proportional to the system clock switching speed, running the device at the lowest possible fre
  • Interfacing TMS320VC5510 to SBSRAM (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 16 июн 2003
    The TMS320C55xв„ў(C55xв„ў) External Memory Interface (EMIF) supports a glueless interface to high-density and high-speed synchronous burst static random access memories (SBSRAM). For clocking SBSRAMs, the EMIF can operate at numerous C55x DSP CPU clock output frequency multiples. Examples are given for system-level connection and register configuration for the different types of SBSRAM mem
  • Using the TMS320VC5510 Bootloader (Rev. C)
    PDF, 269 Кб, Версия: C, Файл опубликован: 19 окт 2004
    This document describes the features of the on-chip bootloader provided with the TMS320VC5510 Digital Signal Processor (DSP). Included are descriptions of each of the available boot modes and any interfacing requirements associated with them, instructions on generating the boot table, and information on migration from the prototype (TMX320VC5510, revision 1.x) to the production (TMS320VC5510) boot
  • TMS320VC5510/5510A Hardware Designer's Resource Guide (Rev. A)
    PDF, 100 Кб, Версия: A, Файл опубликован: 20 апр 2005
    The DSP Hardware Designer's Resource Guide is organized by development flow and functional areas to make your design effort as seamless as possible. Topics covered include getting started, board design, system testing, and checklists to aid in your initial design and debug efforts. Each section includes pointers to valuable information including technical documentation, models, symbols, and refer
  • TMS320VC5510 HPI Throughput and Optimization
    PDF, 83 Кб, Файл опубликован: 27 май 2004
    This application report summarizes some characteristics relevant to understanding TMS320VC5510 host port interface (HPI), and proposes recommendations to optimize throughput on the HPI peripheral.
  • TMS320VC5510 Power Consumption Summary
    PDF, 78 Кб, Файл опубликован: 12 ноя 2003
    This document assists in the estimation of power consumption for the TMS320C5510 digital signal processor (DSP). As power consumption can vary widely on this device, a spreadsheet was developed to provide a better estimate. This allows the user to tailor the prediction to their particular application. It also allows designers the ability to test the efficiency of different configurations before an
  • Migrating from TMS320VC5510 to TMS320VC5502
    PDF, 187 Кб, Файл опубликован: 28 фев 2003
    This document describes issues of interest related to migration from the TMS320VC5510 to the TMS320VC5502. The objective of this document is to indicate differences between the two devices. Functions that are identical between the two devices are not included. For detailed information on the specific functions of either device, refer to the following data manuals and reference guides: the TMS320VC
Серия: TMS320VC5510 (3)
  • Semiconductors > Processors > Digital Signal Processors > C5000 DSP > C55x DSP
На английском языке: Datasheet Texas Instruments TMS320VC5510GGW21
