Datasheet Texas Instruments SN74LVC1G19DRLR — Даташит
| Серия | SN74LVC1G19 |
| Модель | SN74LVC1G19DRLR |
Декодер/демультиплексор 1 из 2 6-SOT-5X3 от -40 до 85
SN74LVC1G19 1-of-2 Decoder and Demultiplexer datasheet
PDF, 1.3 Мб, Версия: G, Файл опубликован: 31 авг 2015
Купить SN74LVC1G19DRLR на РадиоЛоцман.Цены — от 3.83 до 28 ₽41 предложений от 16 поставщиков Интегральные микросхемы Логические микросхемы - Сигнальные коммутаторы, Мультиплексоры, Декодеры | |||
| SN74LVC1G19DRLR Texas Instruments | 9.56 ₽ | ||
| SN74LVC1G19DRLR Texas Instruments | от 26 ₽ | ||
| SN74LVC1G19DRLR Texas Instruments | по запросу | ||
| Pin | 6 | 6 |
| Package Type | DRL | DRL |
| Industry STD Term | SOT-5X3 | SOT-5X3 |
| JEDEC Code | R-PDSO-N | R-PDSO-N |
| Package QTY | 4000 | 4000 |
| Carrier | LARGE T&R | LARGE T&R |
| Маркировка | CY7 | CYR |
| Width (мм) | 1.2 | 1.2 |
| Length (мм) | 1.6 | 1.6 |
| Thickness (мм) | .55 | .55 |
| Pitch (мм) | .5 | .5 |
| Max Height (мм) | .6 | .6 |
| 3-State Output | No |
| Bits | 1 |
| F @ Nom Voltage(Max) | 150 Mhz |
| Gate Type | DECODER/DEMUX |
| ICC @ Nom Voltage(Max) | 0.01 мА |
| Logic | True |
| Output Drive (IOL/IOH)(Max) | 32/-32 мА |
| Package Group | SOT-5X3 |
| Package Size: mm2:W x L | 6SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Special Features | Ioff,down translation to Vcc,low power |
| Sub-Family | Decoder/Encoder/Multiplexer |
| Technology Family | LVC |
| VCC(Max) | 5.5 В |
| VCC(Min) | 1.65 В |
| Voltage(Nom) | 1.8,2.5,3.3,5 В |
| tpd @ Nom Voltage(Max) | 16.1,6.5,5.2,3.9 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1G19 (11)
- Semiconductors > Logic > Little Logic
