Datasheet Texas Instruments LM339DRG3 — Даташит
СерияLM339
МодельLM339DRG3
Четверной дифференциальный компаратор 14-SOIC от 0 до 70
LMx39x, LM2901xx Quad Differential Comparators datasheet
PDF, 1.4 Мб, Версия: T, Файл опубликован: 30 июн 2015
25 предложений от 14 поставщиков
IC COMPARATOR DIFF QUAD 14SOIC. Comparator Differential CMOS, MOS, Open-Collector, TTL 14-SOIC. Linear - Comparators
LM339DRG3
7.46 ₽
LM339DRG3
от 16 ₽
LM339DRG3
LM339DRG3
Pin14
Package TypeD
Package QTY2500
МаркировкаLM339
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Input Bias Current (+/-)(Max)50 нА
Iq per channel(Max)0.5 мА
Количество каналов4
Тип выходаOpen Collector
Propagation Delay Time0.3 uS
Rail-to-RailOut
Special FeaturesN/A
VICR(Max)28.5 В
Vos (Offset Voltage @ 25C)(Max)5 мВ
Vs(Max)30 В
Vs(Min)2 В
  • A Quad of Independently Func Comparators (Rev. A)
    PDF, 1.6 Мб, Версия: A, Файл опубликован: 23 апр 2013
    This application note discusses the features, design, and uses of the LM139/LM239/LM339 family ofdevices.
  • Designing Overcurrent protection for TPL7407L Peripheral Driver
    PDF, 177 Кб, Файл опубликован: 5 ноя 2014
    Microcontroller units (MCUs) are generally limited with lower drive on the I/Os. Most of the applicationsrequiring MCU boards to drive high-current loads need discrete implementation and additional components which use a lot of board space. This board space is called a peripheral driver section. The TPL7407L device is an integrated peripheral driver with seven channel drivers inside. The TPL740
  • Semiconductors > Amplifiers > Comparators
На английском языке: Datasheet Texas Instruments LM339DRG3
