Datasheet Texas Instruments TLV1548CDBLE — Даташит
Серия | TLV1548 |
Модель | TLV1548CDBLE |
10-разрядный АЦП, 85 тыс.
Low-Voltage 10-Bit A-D Converters w/Serial Control and 4/8 Analog Inputs datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 21 янв 1999
TLV1548CDBLE | по запросу |
операций в секунду, сер. Выход, программируемое питание/Pwrdn/скорость преобразования, совместимость с TMS320 DSP/SPI/QPSI, 8 каналов. 20-ССОП
Pin | 20 |
Package Type | DB |
Industry STD Term | SSOP |
JEDEC Code | R-PDSO-G |
Width (мм) | 5.3 |
Length (мм) | 7.2 |
Thickness (мм) | 1.95 |
Pitch (мм) | .65 |
Max Height (мм) | 2 |
Mechanical Data | Скачать |
# Input Channels | 8 |
Analog Voltage AVDD(Max)(V) | 5.5 |
Analog Voltage AVDD(Min)(V) | 2.7 |
Approx. Price (US$) | 2.42 | 1ku |
Архитектура | SAR |
Digital Supply(Max)(V) | 5.5 |
Digital Supply(Min)(V) | 2.7 |
INL(Max)(+/-LSB) | 1 |
Input Range(Max)(V) | 5.5 |
Тип входа | Single-Ended |
Integrated Features | N/A |
Interface | Serial SPI |
Multi-Channel Configuration | Multiplexed |
Operating Temperature Range(C) | -40 to 85 |
Package Group | SSOP |
Package Size: mm2:W x L (PKG) | 20SSOP: 56 mm2: 7.8 x 7.2(SSOP) |
Power Consumption(Typ)(mW) | 1.05 |
Rating | Catalog |
Reference Mode | Ext |
Resolution(Bits) | 10 |
Sample Rate (max)(SPS) | 85kSPS |
RoHS | Не совместим |
- Interfacing the TLV1544/1548 Analog Digital Converter to Digital ProcessorsPDF, 266 Кб, Файл опубликован: 1 авг 1997
This Application Report describes the hardware and software requirements for interfacing an A/D converter to a DSP and to a MCU. The 10-bit A/D converter TLV1544 (4 analog input channels) and the TLV1548 (8 analog input channels) from Texas Instruments have been used to develop such interface. Example software code has been written showing how to program the DSP and the MCU to control the A/D conv - Choosing an ADC and Op Amp for Minimum OffsetPDF, 72 Кб, Файл опубликован: 28 окт 1999
Designing a mixed-signal circuit containing analog and digital components can be a challenge to the development engineer. Requirements such as a low single-polarity supply voltage and a high degree of precision may conflict, and make the choice of components and the best circuit design difficult. This report discusses problems that arise in using operational amplifiers (op amps) for signal conditi - Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
Серия: TLV1548 (7)
- TLV1548CDB TLV1548CDBG4 TLV1548CDBLE TLV1548CDBR TLV1548IDB TLV1548IDBG4 TLV1548IDBR
- Semiconductors > Data Converters > Analog to Digital Converter > Precision ADC (<=10MSPS)
