Datasheet Texas Instruments UCC3819AD — Даташит
| Серия | UCC3819A |
| Модель | UCC3819AD |
Предварительный регулятор коэффициента мощности BiCMOS 16-SOIC от 0 до 70
UCC2819A Power Factor Preregulator datasheet
PDF, 1.0 Мб, Файл опубликован: 9 сен 2003
Купить UCC3819AD на РадиоЛоцман.Цены — от 43 до 452 ₽25 предложений от 19 поставщиков Интегральные микросхемы Микросхемы управления электропитанием - Коррекция коэффициента мощности | |||
| UCC3819AD Texas Instruments | 155 ₽ | ||
| UCC3819AD Unitrode | 163 ₽ | ||
| UCC3819AD Texas Instruments | от 270 ₽ | ||
| UCC3819AD | по запросу | ||
| Pin | 16 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 40 |
| Carrier | TUBE |
| Маркировка | UCC3819AD |
| Width (мм) | 3.91 |
| Length (мм) | 9.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Control Method | CCM |
| Device Type | Single-phase PFC |
| Operating Supply Current | 4 мА |
| Operating Supply(Max) | 17 В |
| Рабочий диапазон температур | от 0 до 70 C |
| Package Group | SOIC |
| Package Size: mm2:W x L | 16SOIC: 59 mm2: 6 x 9.9(SOIC) PKG |
| Peak Output Sink Current Gate Drive | 1.2 A |
| Peak Output Source Current Gate Drive | -1.2 A |
| Practical Operating Frequency(Max) | 0.25 МГц |
| Rating | Catalog |
| Special Features | Average Current Mode,Enable,OVP |
| Startup Current | 0.15 мА |
| UVLO Thresholds On/Off | 10.2/9.7 В |
- PFC Family Differences UCC3817A/18A/19A and UCC3817/18/19PDF, 32 Кб, Файл опубликован: 18 авг 2003
The UCC3817A/18A/19A family of PFC controllers (UCC3817A family) is pin for pin compatible with the UCC3817/18/19 family of devices (UCC3817 family). The output stage of UCC3817A family has been updated to allow use of a smaller external gate drive resistor values. For some power supply designs where an adequately high enough gate drive resistor can not be used, the UCC3817A family offers a more r - UCC3817 Current Sense Transformer EvaluationPDF, 49 Кб, Файл опубликован: 13 фев 2004
- Synchronizing a PFC Controller from a Down Stream Controller Gate DrivePDF, 103 Кб, Файл опубликован: 3 ноя 2000
Due to pending line harmonic requirements at higher power levels, power factor correction (PFC) is required in some ac-to-dc off-line power converter applications. This type of power converter can be designed with two cascaded power stages similar to the configuration in Figure 1. The first stage is a boost converter that converts the ac voltage to dc voltage with PFC. The output voltage of the bo - Startup Current transient of the Leading Edge Triggered PFC ControllersPDF, 43 Кб, Файл опубликован: 30 июн 2004
- Avoiding Audible Noise at Light Loads When Using Leading Edge Triggered PFC Con (Rev. C)PDF, 57 Кб, Версия: C, Файл опубликован: 13 апр 2011
This application note applies to the TI average current mode, leading edge modulation PFC controllers. See Applicable Device Table for part numbers. - DN-66 UC3854A/B and UC3855A/B Provide Power Limiting with Sinusoidal Input (Rev. A)PDF, 80 Кб, Версия: A, Файл опубликован: 6 ноя 2001
Серия: UCC3819A (4)
- UCC3819AD UCC3819ADG4 UCC3819APW UCC3819APWG4
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Power Factor Correction
