Datasheet Texas Instruments SN74AHC123APWR — Даташит
СерияSN74AHC123A
МодельSN74AHC123APWR
Двойные моностабильные мультивибраторы с перезапуском 16-TSSOP от -40 до 85
SN54AHC123A, SN74AHC123A datasheet
PDF, 1.2 Мб, Версия: H, Файл опубликован: 21 окт 2005
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаHA123A
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Bits2
F @ Nom Voltage(Max)110 Mhz
ICC @ Nom Voltage(Max)0.04 мА
Output Drive (IOL/IOH)(Max)50/-50 мА
Package GroupTSSOP
Package Size: mm2:W x L16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
Schmitt TriggerNo
Technology FamilyAHC
VCC(Max)5.5 В
VCC(Min)2 В
Voltage(Nom)3.3,5 В
tpd @ Nom Voltage(Max)29.5,17 нс
  • Designing With the SN74AHC123A and SN74AHCT123A
    PDF, 85 Кб, Файл опубликован: 1 окт 1999
    This application report is designed to answer any questions that the user may have on the operation of the SN74AHC/AHCT123A. It also covers the most frequently asked questions and includes detailed instructions on how to calculate the external components required to make the device function correctly. Several circuits using this device also are included to show the versatility of operation
  • Designing with the SN74LVC1G123 Monostable Multivibrator
    PDF, 158 Кб, Файл опубликован: 14 июл 2015
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • Advanced High-Speed CMOS (AHC) Logic Family (Rev. C)
    PDF, 102 Кб, Версия: C, Файл опубликован: 2 дек 2002
    The Texas Instruments (TI) advanced high-speed CMOS (AHC) logic family provides a natural migration for high-speed CMOS (HCMOS) users who need more speed for low-power and low-drive applications. Unlike many other advanced logic families AHC does not have the drawbacks that come with higher speed e.g. higher signal noise and power consumption. The AHC logic family consists of gates medium-sca
  • Semiconductors > Logic > Specialty Logic > Monostable Multivibrator
На английском языке: Datasheet Texas Instruments SN74AHC123APWR
