Datasheet Texas Instruments SN74LVT125QPWRG4Q1 — Даташит
| Серия | SN74LVT125-Q1 |
| Модель | SN74LVT125QPWRG4Q1 |
Автомобильный каталог Буферы с четырьмя шинами ABT, 3,3 В, с выходами с 3 состояниями, 14-TSSOP от -40 до 125
3.3-V ABT Quadruple Bus Buffer With 3-State Outputs datasheet
PDF, 793 Кб, Версия: B, Файл опубликован: 9 апр 2008
Купить SN74LVT125QPWRG4Q1 на РадиоЛоцман.Цены — от 32 до 108 ₽27 предложений от 15 поставщиков Микросхема Логический контроллер, Automotive Catalog 3.3V ABT Quadruple Bus Buffers With 3-State Outputs 14-TSSOP -40℃ to 125℃ | |||
| SN74LVT125QPWRG4Q1 Rochester Electronics | 32 ₽ | ||
| SN74LVT125QPWRG4Q1 Texas Instruments | 40 ₽ | ||
| SN74LVT125QPWRG4Q1 Texas Instruments | 42 ₽ | ||
| SN74LVT125QPWRG4Q1 Texas Instruments | от 45 ₽ | ||
| Pin | 14 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | LVT125Q |
| Width (мм) | 4.4 |
| Length (мм) | 5 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Bits | 4 |
| F @ Nom Voltage(Max) | 100 Mhz |
| ICC @ Nom Voltage(Max) | 0.007 мА |
| Output Drive (IOL/IOH)(Max) | -32/32 мА |
| Package Group | TSSOP |
| Package Size: mm2:W x L | 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG |
| Rating | Automotive |
| Schmitt Trigger | No |
| Technology Family | LVT |
| VCC(Max) | 3.6 В |
| VCC(Min) | 2.7 В |
| Voltage(Nom) | 3.3 В |
| tpd @ Nom Voltage(Max) | 4.2 нс |
- LVT Family Characteristics (Rev. A)PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti - LVT-to-LVTH ConversionPDF, 84 Кб, Файл опубликован: 8 дек 1998
Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVT125-Q1 (4)
- SN74LVT125QDRG4Q1 SN74LVT125QDRQ1 SN74LVT125QPWRG4Q1 SN74LVT125QPWRQ1
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
