Datasheet Texas Instruments TPS61235RWLT — Даташит
СерияTPS61235
МодельTPS61235RWLT
TPS6123x Синхронные повышающие преобразователи тока пониженного тока, 8 А с функцией стабилизации выходного тока 9-VQFN-HR от -40 до 85
Datasheet
TSP
Pin9
Package TypeRWL
Industry STD TermVQFN-HR
JEDEC CodeS-PQFP-N
CarrierSMALL T&R
МаркировкаZBBI
Width (мм)2.5
Length (мм)2.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
RoHSНе совместим
  • Evaluation Modules & Boards: TPS61236EVM-676
    TPS61236 Large Current Boost Converter Evaluation Module
  • Automated Frequency Response Analyzer
    PDF, 939 Кб, Файл опубликован: 9 окт 2013
    This application report discusses a new method of doing stability Analysis testing by using basic labequipment, while not requiring any specific instruments.
  • Five Steps to a Good PCB Layout of the Boost Converter
    PDF, 701 Кб, Файл опубликован: 3 май 2016
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Design considerations for a resistive feedback divider in a DC/DC converter
    PDF, 393 Кб, Файл опубликован: 26 апр 2012
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)
    PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
Серия: TPS61235 (2)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS61235RWLT
