Datasheet Texas Instruments F28M35H22C1RFPS — Даташит
СерияF28M35H22C
МодельF28M35H22C1RFPS
Концертный микроконтроллер 144-HTQFP от -40 до 125
F28M35x Concerto Microcontrollers datasheet
PDF, 2.2 Мб, Версия: I, Файл опубликован: 8 июн 2015
Pin144
Package TypeRFP
Industry STD TermHTQFP
JEDEC CodeS-PQFP-G
Package QTY60
МаркировкаF28M35H22C1RFPS
Width (мм)20
Length (мм)20
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
# of ADC Modules2
12-bit A/D20 #Channels
ADC Channels20
ADC Conversion Time172 нс
ADC Resolution12-bit
ADC Sample & HoldDual
CAN2
CPUC28x, Cortex-M3
DMA1 6-Ch DMA, 1 32-ch DMA Ch
EMIFYes
Ethernet1
FPUYes
Flash512 KB
Тактовая частота150,100 МГц
GPIO64
Generation28x + ARM Cortex M3 Concerto Series
I2C3
IO Supply3.3 В
McBSP1
Рабочий диапазон температурот -40 до 105,-40 до 125 C
PWM24 Ch
Package GroupHTQFP
Package Size: mm2:W x L144HTQFP: 484 mm2: 22 x 22(HTQFP) PKG
RAM136 KB
RISC Frequency75,100 МГц
SPI5
Timers3 32-Bit CPU,1 WD
Total On-Chip Memory648 KB
Total Serial Ports2 CANs,3 I2C,5 SPI,6 SCIs,1 McBSP,1 USB,1 Ethernet
UART6
USB1
  • Evaluation Modules & Boards: TMDSSOLARCEXPKIT
    Concerto-based Solar Explorer Development Kit
  • Daughter Cards: TMDSCNCDH52C1
    H52C1 Concerto controlCARD
  • Evaluation Modules & Boards: TMDSDOCKH52C1
    H52C1 Concerto Experimenter Kit
  • JTAG Emulators/ Analyzers: C2000-GANG
    C2000 Gang Programmer
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-20T
    XDS100v2 JTAG Debug Probe (20-pin cTI version)
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-14T
    XDS100v2 JTAG Debug Probe (14-pin TI version)
    XDS200 USB Debug Probe
  • Calculating Useful Lifetimes of Embedded Processors
    PDF, 521 Кб, Файл опубликован: 11 ноя 2014
    This application report provides a methodology for calculating the useful lifetime of TI embedded processors (EP) under power when used in electronic systems. It is aimed at general engineers who wish to determine if the reliability of the TI EP meets the end system reliability requirement.
  • Calculator for CAN Bit Timing Parameters
    PDF, 37 Кб, Файл опубликован: 22 мар 2016
    Controller Area Network (CAN) nodes use user-specified timing parameters to sample the asynchronous bitstream and recover the clock. These parameters are typically based on the frequency of the available reference oscillator. There may be several options available for a given frequency, and some of them will allow a looser oscillator tolerance than others. This application report details the creat
Серия: F28M35H22C (3)
  • Semiconductors > Microcontrollers (MCU) > Performance MCUs > Control + Automation > F28M3x
На английском языке: Datasheet Texas Instruments F28M35H22C1RFPS
