Datasheet Texas Instruments TPA2016D2RTJT — Даташит
СерияTPA2016D2
МодельTPA2016D2RTJT
Стереоусилитель звука класса D мощностью 2,8 Вт/канал с технологией SmartGainTM AGC/DRC (TPA2016) 20-QFN от -40 до 85
TPA2016D2 2.8-W/Ch Stereo Class-D Audio Amplifier With Dynamic Range Compression and Automatic Gain Control datasheet
PDF, 1.4 Мб, Версия: E, Файл опубликован: 31 май 2016
Pin2020
Package TypeRTJRTJ
Industry STD TermWQFNWQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY250250
CarrierSMALL T&RSMALL T&R
Маркировка2016D2TPA
Width (мм)44
Length (мм)44
Thickness (мм).73.73
Pitch (мм).5.5
Max Height (мм).8.8
Analog Supply (V)5.5 Min
АрхитектураClass D
Audio Input TypeAnalog Input
Control InterfaceI2C
Iq per channel(Typ)2.25 мА
Iq(Max)5.5 мА
Iq(Typ)4.5 мА
Load(Min)4 ohms
Выходная мощность2.8 W
PSRR80 дБ
Package GroupQFN
Package Size: mm2:W x L20QFN: 16 mm2: 4 x 4(QFN) PKG
Pin/Package16DSBGA, 20QFN
Shutdown Current (ISD)0.2 uA
Speaker ChannelsStereo Max
THD + N @ 1 kHz1 %
  • Evaluation Modules & Boards: TPA2016D2EVM
    TPA2016D2 Evaluation Module (EVM)
  • TPA2016D2 Input Filtering
    PDF, 141 Кб, Файл опубликован: 15 июл 2008
  • Filter-Free Class-D Audio Amplifiers
    PDF, 259 Кб, Файл опубликован: 9 ноя 2009
    Traditional Class-D amplifiers lose efficiency if they do not use output LC filters. Texas Instruments offers many Class-D amplifiers that are designated Filter-Free. This means they do not require an output LC filter to maintain high efficiency. However, in some cases an LC or ferrite bead filter is required for EMC.
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA2016D2 (5)
  • Semiconductors > Audio > Low-Power Audio Amplifiers (<10W) > Speaker Amplifier Class AB/Class D
На английском языке: Datasheet Texas Instruments TPA2016D2RTJT
