Datasheet Texas Instruments SN74HC165DE4 — Даташит
| Серия | SN74HC165 |
| Модель | SN74HC165DE4 |
8-битные сдвиговые регистры с параллельной загрузкой 16-SOIC от -40 до 125
SNx4HC165 8-Bit Parallel-Load Shift Registers datasheet
PDF, 1.2 Мб, Версия: H, Файл опубликован: 30 дек 2015
Купить SN74HC165DE4 на РадиоЛоцман.Цены — от 12 до 90 ₽18 предложений от 14 поставщиков Микросхема Регистр сдвига, TEXAS INSTRUMENTS SN74HC165DE4 Shift Register, HC Family, 74HC165, Parallel to Serial, 1Element, 8Bit, SOIC, 16Pins | |||
| SN74HC165DE4 Texas Instruments | 12 ₽ | ||
| SN74HC165DE4 Texas Instruments | 19 ₽ | ||
| SN74HC165DE4 Texas Instruments | по запросу | ||
| Pin | 16 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 40 |
| Carrier | TUBE |
| Маркировка | HC165 |
| Width (мм) | 3.91 |
| Length (мм) | 9.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| 3-State Output | No |
| F @ Nom Voltage(Max) | 28 Mhz |
| ICC @ Nom Voltage(Max) | 0.08 мА |
| Output Drive (IOL/IOH)(Max) | 5.2/-5.2 мА |
| Package Group | SOIC |
| Package Size: mm2:W x L | 16SOIC: 59 mm2: 6 x 9.9(SOIC) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | HC |
| VCC(Max) | 6 В |
| VCC(Min) | 2 В |
| Voltage(Nom) | 6 В |
| tpd @ Nom Voltage(Max) | 38 нс |
- HCMOS Design Considerations (Rev. A)PDF, 207 Кб, Версия: A, Файл опубликован: 9 сен 2002
This document describes a potential problem designers may encounter when using high-speed CMOS (HC) logic devices. There also is a broad range of CMOS-system to non-CMOS-system interfaces that need to be considered. The design engineer inevitably encounters these interfaces. Key considerations for handling these interfaces are also discussed in this book.
Серия: SN74HC165 (22)
- Semiconductors > Logic > Flip-Flop/Latch/Register > Shift Register
