Datasheet Texas Instruments VCA8617PAGR — Даташит
СерияVCA8617
МодельVCA8617PAGR
8-канальный усилитель с переменным коэффициентом усиления 64-TQFP от -40 до 85
Eight-Channel Variable Gain Amplifier datasheet
PDF, 718 Кб, Версия: F, Файл опубликован: 18 ноя 2009
Pin64
Package TypePAG
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Package QTY1500
МаркировкаVCA8617
Width (мм)10
Length (мм)10
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Acl, min spec gain1.8 V/V
BW @ Acl100 МГц
Max Gain58 дБ
Количество каналов8
PGA/VGAVGA
Package GroupTQFP
Package Size: mm2:W x L64TQFP: 144 mm2: 12 x 12(TQFP) PKG
Slew Rate(Typ)300 V/us
Vs(Max)3.15 В
Vs(Min)2.85 В
  • VCA8617: Response to Step-Change in Gain Control
    PDF, 102 Кб, Файл опубликован: 24 мар 2005
    The VCA8617 is an 8-channel variable gain amplifier ideally suited for portable and mid-range ultrasound applications. Each channel consists of a Low Noise Amplifier (LNA) and a Variable Gain Amplifier (VGA). The VGA contains two parts: a voltage-controlled attenuator (VCA) and a programmable gain amplifier (PGA). The PGA output feeds directly into an integrated 3-pole low-pass Butterworth filter.
  • AB-170: Ultrasound Processor Supplementary Material
    PDF, 752 Кб, Файл опубликован: 25 янв 2001
    An ultrasound system employs a multichannel phased array of acoustic elements to form an image. Previous implementation of this function has used bipolar technology. 0.5u CMOS technology has the advantage of lowering the cost and increasing functionality compared to using bipolar technology.
  • Interfacing the VCA8617 with High-Speed ADCs
    PDF, 72 Кб, Файл опубликован: 5 апр 2005
    The VCA8617 is an 8-channel variable gain amplifier ideally suited for portable and mid-range ultrasound applications. Each channel consists of a Low Noise Amplifier (LNA) and a Variable Gain Amplifier (VGA). The VGA contains two parts: a voltage-controlled attenuator and a programmable gain amplifier. The PGA output feeds directly into an integrated 3-pole low-pass Butterworth filter, which preve
Серия: VCA8617 (3)
  • Semiconductors > Amplifiers > Programmable & Variable Gain Amplifiers (PGA/VGA)
На английском языке: Datasheet Texas Instruments VCA8617PAGR
