Datasheet Texas Instruments REG1117-2.85 — Даташит
СерияREG1117
МодельREG1117-2.85
1A Положительный регулятор с малым падением напряжения 4-SOT-223 0–125
REG1117: 800mA 1A Low Dropout Pos Regulator 1.8, 2.5, 2.85, 3.3, 5V, Adjustable datasheet
PDF, 846 Кб, Версия: D, Файл опубликован: 21 июл 2004
34 предложений от 26 поставщиков
Микросхемы управления электропитанием - Стабилизаторы напряжения - Линейные
REG1117-2.85
32 ₽
REG1117-2.85/2K5
81 ₽
REG1117-2.85G4
240 ₽
LifeElectronics
REG1117-2.85G4
Pin4
Package TypeDCY
Industry STD TermSOT-223
Package QTY80
МаркировкаBB11172
Width (мм)3.5
Length (мм)6.5
Thickness (мм)1.6
Pitch (мм)2.3
Max Height (мм)1.8
Точность2 %
Fixed Output Options2.5,2.8,2.85,3,3.3,5 В
Iout(Max)0.8 A
Iq(Typ)4 мА
Noise38 uVrms
Рабочий диапазон температурот 0 до 125 C
PSRR @ 100KHz29 дБ
Package GroupSOT-223
Package Size: mm2:W x L4SOT-223: 46 mm2: 7 x 6.5(SOT-223) PKG
Regulated Outputs1
Special FeaturesN/A
Thermal Resistance ОёJA65 В°C/W
Vdo(Typ)1100 мВ
Vin(Max)15 В
Vin(Min)3.7 В
Vout(Max)13.8 В
Vout(Min)1.25 В
  • An Easy Solution to Current Limiting an Op Amp
    PDF, 35 Кб, Файл опубликован: 2 окт 2000
    Many circuits today not only require voltage regulation but they also need current regulation. Some systems draw excessive current during power on, which can cause expensive system components to burn up due to improper powering of supplies. This is not the only problem associated with excessive currents. Some applications need to limit the current an op amp can provide to a specific load. This cir
  • Packaging Limits Range of Linear Regulators
    PDF, 75 Кб, Файл опубликован: 8 май 2010
    The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
REG11172.85, REG1117 2.85
На английском языке: Datasheet Texas Instruments REG1117-2.85
