Datasheet Texas Instruments THS4531AIDR — Даташит
СерияTHS4531A
МодельTHS4531AIDR
Полностью дифференциальный усилитель сверхмалой мощности, RRO, 8-SOIC от -40 до 125
THS4531A Ultra Low-Power, Rail-to-Rail Output, Fully Differential Amplifier datasheet
PDF, 2.0 Мб, Версия: C, Файл опубликован: 4 янв 2016
Package TypeD
Package QTY2500
МаркировкаT4531A
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
2nd Harmonic129 dBc
3rd Harmonic138 dBc
@ MHz0.001
Acl, min spec gain1 V/V
Additional FeaturesShutdown
АрхитектураFully Differential,Voltage FB
BW @ Acl36 МГц
CMRR(Min)90 дБ
CMRR(Typ)116 дБ
GBW(Typ)27 МГц
Input Bias Current(Max)250000 pA
Iq per channel(Max)0.35 мА
Iq per channel(Typ)0.25 мА
Количество каналов1
Offset Drift(Typ)3 uV/C
Output Current(Typ)26 мА
Rail-to-RailIn to V-,Out
Slew Rate(Typ)220 V/us
Total Supply Voltage(Max)5.5 +5V=5, +/-5V=10
Total Supply Voltage(Min)2.5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)10 нВ/rtГц
Vn at Flatband(Typ)10 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.4 мВ
  • Evaluation Modules & Boards: THS4531ADGKEVM
    THS4531ADGKEVM Evaluation Module
  • Using fully differential op amps as attenuators, Part 1
    PDF, 554 Кб, Файл опубликован: 1 май 2009
  • Using fully differential op amps as attenuators, Part 3
    PDF, 568 Кб, Файл опубликован: 4 окт 2009
  • Using fully differential op amps as attenuators, Part 2
    PDF, 531 Кб, Файл опубликован: 14 июл 2009
  • Analysis of fully differential amplifiers
    PDF, 295 Кб, Файл опубликован: 11 мар 2005
  • Fully-Differential Amplifiers (Rev. E)
    PDF, 867 Кб, Версия: E, Файл опубликован: 19 сен 2016
    Differential signaling has been commonly used in audio, data transmission, and telephone systems for many years because of its inherent resistance to external noise sources. Today, differential signaling is becoming popular in high-speed data acquisition, where the ADC’s inputs are differential and a differential amplifier is needed to properly drive them.Two other advantages of di
  • Designing for low distortion with high-speed op amps
    PDF, 277 Кб, Файл опубликован: 2 мар 2005
На английском языке: Datasheet Texas Instruments THS4531AIDR
