Datasheet ТI TLC5923RHBR — Даташит
СерияTLC5923
МодельTLC5923RHBR
Datasheet Texas Instruments TLC5923RHBR
16-канальный светодиодный драйвер с коррекцией точек 32-VQFN от -40 до 85
TLC5923 16 Channel LED Driver With DOT Correction datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 31 янв 2013
  • LED Driver--Paralleled Outputs Provide High Current Outputs
    PDF, 957 Кб, Файл опубликован: 25 сен 2006
    This application report describes how to use the TLC5922, TLC5923, and TLC5924 to drive high-current LEDs. These ICs are designed to provide 16 individually controllable constant-current sinks. However, the 16 outputs can be connected in parallel to increase the current drive capability. Paralleling the outputs of these ICs allows the TLC5922, TLC5923, and TLC5924 to drive high-power LEDs such as
  • Semiconductors > Power Management > LED Driver > Signage & Large Display LED Driver
На английском языке: Datasheet Texas Instruments TLC5923RHBR
Политика конфиденциальности
