Datasheet Texas Instruments LM2903QDG4 — Даташит
СерияLM2903
МодельLM2903QDG4
Двойной дифференциальный компаратор 8-SOIC от -40 до 125
Datasheet LM193, LM293, LM293A, LM393, LM393A, LM2903, LM2903V
PDF, 1.6 Мб, Версия: Y, Файл опубликован: 30 июн 2015, Страниц: 37
Dual Differential Comparators
IC COMPARATOR DIFF DUAL 8SOIC. Comparator Differential CMOS, MOS, Open-Drain, TTL 8-SOIC. Linear - Comparators
LM2903QDG4
11 ₽
LM2903QDG4
15 ₽
LM2903QDG4
48 ₽
Эиком
LM2903QDG4
от 96 ₽
Package TypeD
Package QTY75
CarrierSMALL T&R
Маркировка2903Q
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Input Bias Current (+/-)(Max)50 нА
Iq per channel(Max)0.5 мА
Количество каналов2
Тип выходаOpen Collector
Propagation Delay Time1.3 uS
Rail-to-RailOut
Special FeaturesN/A
VICR(Max)28.5 В
Vos (Offset Voltage @ 25C)(Max)7 мВ
Vs(Max)30 В
Vs(Min)2 В
  • Designing Overcurrent protection for TPL7407L Peripheral Driver
    PDF, 177 Кб, Файл опубликован: 5 ноя 2014
    Microcontroller units (MCUs) are generally limited with lower drive on the I/Os. Most of the applicationsrequiring MCU boards to drive high-current loads need discrete implementation and additional components which use a lot of board space. This board space is called a peripheral driver section. The TPL7407L device is an integrated peripheral driver with seven channel drivers inside. The TPL740
  • Semiconductors > Amplifiers > Comparators
На английском языке: Datasheet Texas Instruments LM2903QDG4
