Линейка продуктов KEEN SIDE
Datasheet Texas Instruments ADS7870EA — Даташит
СерияADS7870
МодельADS7870EA
12-разрядный АЦП, мультиплексор, PGA и внутренняя опорная система сбора данных 28-SSOP от -40 до 85
12-Bit ADC, MUX, PGA and Internal Reference Data Acquisition System datasheet
PDF, 885 Кб, Версия: C, Файл опубликован: 19 дек 2005
Pin28
Package TypeDB
Industry STD TermSSOP
Package QTY50
МаркировкаADS7870EA
Width (мм)5.3
Length (мм)10.2
Thickness (мм)1.95
Max Height (мм)2
# Input Channels8
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)2.7 В
АрхитектураSAR
Digital Supply(Max)5.5 В
Digital Supply(Min)2.7 В
INL(Max)2.5 +/-LSB
Input Range(Max)5.5 В
Тип входаDifferential,Single-Ended
Integrated FeaturesOscillator,PGA
InterfaceSPI
Package GroupSSOP
Package Size: mm2:W x L28SSOP: 80 mm2: 7.8 x 10.2(SSOP) PKG
Power Consumption(Typ)6 mW
Reference ModeExt,Int
Разрешение12 Bits
SINADN/A дБ
Sample Rate (max)52kSPS SPS
Sample Rate(Max)0.052 MSPS
THD(Typ)N/A дБ
  • Evaluation Modules & Boards: ADS7870EVM
    ADS7870 Evaluation Module
  • Interfacing the ADS7870 and the MC68HC11E9 Analog to Microcomputer Made Easy
    PDF, 82 Кб, Файл опубликован: 27 сен 2000
    Assembly of a data-acquisition system with its many parts (multiplexed, amplifiers, ADC, voltage reference, etc.) can be complex and expensive. The new Burr-Brown ADS7870 solves the problem with its 12-bit low-power CMOS data acquisition system containing all parts mentioned, and extras. The space saving system is in a samll (SSOP-28 surface-mount) plastic package.
  • AB-174: Getting the Full Potential from your ADC (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 28 июн 2002
    Many of today?s high-resolution ADCs (Analog-to-Digital Converters) are operating from a single supply and use fully differential inputs. This can be a problem for single-ended signals that are bipolar relative to common. This article illustrates circuit configurations that preserve the full-scale input range by using modern features, such as Programmable Gain Amplifiers (PGAs) and internal voltag
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
На английском языке: Datasheet Texas Instruments ADS7870EA
