Datasheet Texas Instruments TPS61121RSAR — Даташит
СерияTPS61121
МодельTPS61121RSAR
Повышающий преобразователь 3,3 В с КПД 95 % и LDO 1,5 В, 200 мА для одноэлементных литий-ионных или двухэлементных приложений 16-QFN от -40 до 85
TPS6112x Synchronous Boost Converter With 1.1-A Switch and Integrated LDO datasheet
PDF, 1.5 Мб, Версия: D, Файл опубликован: 28 май 2015
Pin1616
Package TypeRSARSA
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Маркировка1121TPS6
Width (мм)44
Length (мм)44
Thickness (мм).9.9
Pitch (мм).65.65
Max Height (мм)11
Approx. Price (US$)2.00 | 1ku
Duty Cycle(Max)(%)100
Iq(Typ)(mA)0.04
Operating Temperature Range(C)-40 to 85
Package GroupTSSOP
Regulated Outputs(#)2
Special FeaturesEnable
Light Load Efficiency
Load Disconnect
Power Good
Switch Current Limit(Min)(A)1.1
Switch Current Limit(Typ)(A)1.6
Switching Frequency(Max)(kHz)600
Switching Frequency(Min)(kHz)400
ТипConverter
Vin(Max)(V)5.5
Vin(Min)(V)1.8
Vout(Max)(V)3.3
Vout(Min)(V)3.3
RoHSНе совместим
  • Evaluation Modules & Boards: TPS61121EVM-205
    TPS61121 Evaluation Module
  • Evaluation Modules & Boards: TPS61120EVM-205
    TPS61120 Evaluation Module
  • Evaluation Modules & Boards: TPS61122EVM-205
    TPS61122 Evaluation Module
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS61121 (4)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS61121RSAR
