Datasheet Texas Instruments LM57TEPWRQ1 — Даташит
| Серия | LM57-Q1 |
| Модель | LM57TEPWRQ1 |
Automotive Grade, В±0.7В°C Temperature Sensor with Resistor-Programmable Temp Switch 8-TSSOP -50 to 150
LM57-Q1 Resistor-Programmable Temperature Switch and Analog Temperature Sensor datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 29 июл 2015
Купить LM57TEPWRQ1 на РадиоЛоцман.Цены — от 30 до 477 ₽8 предложений от 8 поставщиков THERMOSTAT PROG ACT HI/LO 8TSSOP. Thermostat Programmable Active High, Active Low Open Drain, Push-Pull 8-TSSOP. Temperature Sensors - Thermostats - Solid... | |||
| LM57TEPWRQ1 Texas Instruments | 90 ₽ | ||
| LM57TEPWRQ1 Texas Instruments | по запросу | ||
| Pin | 8 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | LM57TE |
| Width (мм) | 4.4 |
| Length (мм) | 3 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| # Comparators | 1 |
| Accuracy Over Temp Range(Max) | 1.3 C |
| Interface | Analog Output,Switch |
| Рабочий диапазон температур | от -50 до 125,-50 до 150,-50 до 160 C |
| Тип выхода | Open Drain,Push Pull |
| Package Group | TSSOP |
| Package Size: mm2:W x L | 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) PKG |
| Rating | Automotive |
| Sensor Gain | -5.2 to 12.9 mV/Deg C |
| SetPoint Type | Resistor Programmable |
| SetPoint Value | -40 to 160 deg C |
| Special Features | Built-in Hysteresis,Hysteresis (5В°C or 10В°C),Temperature Sensor and Switch,Trip Test |
| Supply Current(Typ) | 24 uA |
| Supply Voltage(Max) | 5.5 В |
| Supply Voltage(Min) | 2.4 В |
Серия: LM57-Q1 (12)
- Semiconductors > Sensing Products > Temperature Sensors > Temperature Switches / Thermostats
