Datasheet Texas Instruments LM6132AIMX — Даташит
СерияLM6132
МодельLM6132AIMX
Двойной операционный усилитель ввода/вывода малой мощности, 10 МГц, Rail-to-Rail, 8-SOIC, от -40 до 85
LM6132/LM6134 Dual and Quad Low Power 10В MHz Rail-to-Rail I/O Operational Amplifiers datasheet
PDF, 1.5 Мб, Версия: E, Файл опубликован: 5 сен 2014
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
Маркировка32AIMLM61
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Рекомендуемая замена
ReplacementLM6132AIMX/NOPB
Replacement CodeS
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)75 дБ
CMRR(Typ)107 дБ
GBW(Typ)10 МГц
Input Bias Current(Max)140000 pA
Iq per channel(Max)0.45 мА
Iq per channel(Typ)0.36 мА
Количество каналов2
Offset Drift(Typ)5 uV/C
Output Current(Typ)4.3 мА
Rail-to-RailIn,Out
Slew Rate(Typ)14 V/us
Total Supply Voltage(Max)24 +5V=5, +/-5V=10
Vn at 1kHz(Typ)27 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)2 мВ
RoHSSee ti.com
  • AN-1237 RSDSв„ў Flat Panel Display Design Guidelines Part 2 (Rev. A)
    PDF, 194 Кб, Версия: A, Файл опубликован: 6 май 2013
    This application report presents part 2 of the flat panel display design guidelines.
  • AN-1234 RSDSв„ў Flat Panel Display Design Guidelines Part 1 (Rev. A)
    PDF, 245 Кб, Версия: A, Файл опубликован: 6 май 2013
    This application report outlines the total system solution that Texas Instruments provides for flat panel displays (FPDs). The described design uses an reduced swing differential signaling (RSDS) interface technology for reduced power, reduced board size, reduced component count, and reduced EMI. This document is currently applicable to XGA and SXGA notebook and monitor applications.
  • AN-1515 A Comprehensive Study of the Howland Current Pump (Rev. A)
    PDF, 165 Кб, Версия: A, Файл опубликован: 26 апр 2013
    It is well known to analog experts that you can use the positive and negative inputs of an operationalamplifier to make a high-impedance current source (current pump) using a conventional operationalamplifier (op amp). This basic circuit can put out both + and - output current (or zero current) into variousloads. The theory is simple. But the practical problems involved are not so simple or
На английском языке: Datasheet Texas Instruments LM6132AIMX
