Datasheet Texas Instruments TPS61150ADRCRG4 — Даташит
СерияTPS61150A
МодельTPS61150ADRCRG4
Драйвер WLED с двойным выходом и одной катушкой индуктивности 10-VSON от -40 до 85
Dual Output Boost WLED Driver Using Single Inductor datasheet
PDF, 1.1 Мб, Файл опубликован: 6 окт 2006
Pin10
Package TypeDRC
Industry STD TermVSON
JEDEC CodeS-PDSO-N
Width (мм)3
Length (мм)3
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Approx. Price (US$)0.90 | 1ku
Channels(#)2
Duty Cycle(Max)(%)93
LED Current Per Channel(mA)23
LED(#)12
Operating Temperature Range(C)-40 to 85
Package GroupVSON
Package Size: mm2:W x L (PKG)10VSON: 9 mm2: 3 x 3(VSON)
Peak Efficiency(%)83
Shutdown Current(Typ)(uA)1.5
Special FeaturesSynchronous Rectification
Switching Frequency(Max)(kHz)1200
TopologyBoost
ТипInductive
Vin(Max)(V)6
Vin(Min)(V)2.5
Vout(Max)(V)27
Vout(Min)(V)2.5
RoHSНе совместим
  • Evaluation Modules & Boards: TPS61150AEVM-150
    TPS61150AEVM-150 Evaluation Module
  • Powering Multiple WLED Strings Using the TPS61150/50A
    PDF, 107 Кб, Файл опубликован: 14 мар 2007
    This application report describes how to regulate more than two white light-emitting diodes (WLED) using the TPS61150/50A high-frequency boost converter with two regulated current outputs for driving WLEDs.
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
Серия: TPS61150A (4)
  • Semiconductors > Power Management > LED Driver > Backlight
На английском языке: Datasheet Texas Instruments TPS61150ADRCRG4
