Линейка продуктов KEEN SIDE
Datasheet Texas Instruments LM25116MH/NOPB — Даташит
СерияLM25116
МодельLM25116MH/NOPB
Синхронный понижающий контроллер, напряжение 6–42 В, режим тока, 20-HTSSOP от -40 до 125
LM25116 Wide-Range Synchronous Buck Controller datasheet
PDF, 1.9 Мб, Версия: E, Файл опубликован: 23 сен 2016
Pin2020
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY7373
CarrierTUBETUBE
МаркировкаLM25116MH
Width (мм)4.44.4
Length (мм)6.56.5
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Control ModeCurrent Mode
Duty Cycle(Max)98 %
Iout(Max)20 A
Iq(Typ)4.6 мА
Number of Phases1
Package GroupHTSSOP
Regulated Outputs1
Special FeaturesAdjustable Current Limit,Enable,Frequency Synchronization,Light Load Efficiency,Synchronous Rectification
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)50 kHz
ТипController
Vin(Max)42 В
Vin(Min)6 В
Vout(Max)36 В
Vout(Min)1.215 В
  • Evaluation Modules & Boards: LM25116EVAL
    Evaluation Board for LM25116 Wide Vin Synchronous Buck Controller
  • Automated Frequency Response Analyzer
    PDF, 939 Кб, Файл опубликован: 9 окт 2013
    This application report discusses a new method of doing stability Analysis testing by using basic labequipment, while not requiring any specific instruments.
  • Minimizing FET Losses For a High Input Rail Buck Converter (Rev. A)
    PDF, 168 Кб, Версия: A, Файл опубликован: 23 апр 2013
    Engineers often face the challenge of choosing the input voltage rail that works best for the DC-DCconverter at the point-of-load (POL). High voltage rails, above 12 V, usually demand intermediateregulation stages that reduce overall efficiency and add to cost. However, the new generation of regulatorand controller ICs afford POL regulation from these high input rails directly. Typically the
  • Reduce buck-converter EMI and voltage stress by minimizing inductive parasitics
    PDF, 926 Кб, Файл опубликован: 21 июл 2016
Серия: LM25116 (3)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
На английском языке: Datasheet Texas Instruments LM25116MH/NOPB
