Datasheet ТI TPS54240QDRCRQ1 — Даташит
| Серия | TPS54240-Q1 |
| Модель | TPS54240QDRCRQ1 |
Автомобильный понижающий преобразователь 3,5–42 В, 2,5 А с Eco-Mode™ 10-VSON от -40 до 125
3.5 V to 42 V STEP DOWN SWIFT DC/DC CONVERTER WITH ECO-MODE datasheet
PDF, 2.3 Мб, Версия: B, Файл опубликован: 5 сен 2013
- Passing CISPR25 Radiated Emissions Using the TPS54160-Q1PDF, 857 Кб, Файл опубликован: 4 дек 2013
This application report provides a summary of CISPR25-Radiated Emissions test results using the TPS54160-Q1 high-frequency buck converter. Similar results can be achieved using other devices in this family. This family of buck converters is capable of passing CISPR25 and other automotive electromagnetic-compatibility (EMC) test specifications. The TPS54160 family of devices does not require the us - TPS54xx0-Q1 and TPS57xx0-Q1 Pin Open and Short Test Results (Rev. B)PDF, 39 Кб, Версия: B, Файл опубликован: 3 ноя 2015
This application note provides Pin Open and Short Test Results for the device pins of the TPS54xx0-Q1and TPS57xx0-Q1 family of step-down SWIFTв„ў DC-DC converters. The TPS54xx0-Q1 and TPS57xx0-Q1 family of power devices consists of high-input-voltage step-down regulators that provide a variety ofcurrent options. - Interfacing TPS57xxx-Q1 and TPS65320-Q1 Family Devices With Low Impendence ExterPDF, 624 Кб, Файл опубликован: 8 дек 2015
- Design Considerations for DC-DC Converters in Fast-Input Slew Rate ApplicationsPDF, 191 Кб, Файл опубликован: 5 мар 2015
This application report describes the ways to optimize the design of DC-DC converters (TPS54040-Q1, TPS54060-Q1, TPS54140-Q1, TPS54160-Q1, TPS54240-Q1, TPS54260-Q1, TPS57040-Q1, TPS57060-Q1, TPS57140-Q1, and TPS57160-Q1) in applications with fast transition at the input voltage on the rising and falling edges. First, the issues faced under such a scenario are analyzed. Then, design considerations
Серия: TPS54240-Q1 (2)
- TPS54240QDGQRQ1 TPS54240QDRCRQ1
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
