Datasheet Texas Instruments SMV320C6727BHFHM — Даташит
СерияSMV320C6727B-SP
МодельSMV320C6727BHFHM
Процессор цифровых сигналов с плавающей запятой 256-CFP от -55 до 125
Floating-Point Digital Signal Processor. datasheet
PDF, 722 Кб, Версия: G, Файл опубликован: 2 янв 2014
Цифровой сигнальный процессор DSP, DSP Floating-Point 32Bit/64Bit 250MHz 2000MIPS 256Pin CFP
SMV320C6727BHFHM
791 264 ₽
SMV320C6727BHFHM
1 118 010 ₽
SMV320C6727BHFHM
Pin256
Package TypeHFH
Industry STD TermCFP
JEDEC CodeR-CQFP-F
Package QTY1
МаркировкаSMV320C6727BHFHM
Width (мм)7.63
Length (мм)7.63
Thickness (мм)4
Pitch (мм).5
Max Height (мм)4.55
DSP1 C67x+
DSP MHz250 Max.
I2C2
On-Chip L2 Cache32
Рабочий диапазон температурот -55 до 115,-55 до 125,25 Only C
RatingSpace
SPI2
RoHSSee ti.com
  • Configuring External Interrupts on TMS320C672x Devices
    PDF, 730 Кб, Файл опубликован: 11 июл 2008
    Every real-time embedded system needs to be able to interact to events associated with the external world in a timely manner; for this, typically every digital signal processor (DSP) device features one or more dedicated pins, which are used for carrying these external signals, called interrupts, inside the device for further processing by the application. The TMS320C672x generation of processors
  • How to Create Delay-based Audio Effects on a TMS320C6727 DSP
    PDF, 600 Кб, Файл опубликован: 1 ноя 2005
    TMS320C672x is a floating point device family from Texas Instruments that provides high quality audio performance at low prices. The price/performance ratio makes C672x well suited for numerous audio applications. This application note shows how to use C672x to efficiently create delay-based audio effects. The application note explains:How to leverage the data movement accelerator (dM
  • TMS320C6713 to TMS320C672x Migration Guide
    PDF, 182 Кб, Файл опубликован: 23 май 2005
  • TMS320C672x Hardware Designer's Resource Guide (Rev. A)
    PDF, 87 Кб, Версия: A, Файл опубликован: 22 сен 2006
    The DSP Hardware Designer's Resource Guide is organized by development flow and functional areas to make your design effort as seamless as possible. Topics covered include getting started, board design, system testing, and checklists to aid in your initial design and debug efforts. Each section includes pointers to valuable information including technical documentation, models, symbols, and refere
  • C9230C100 TMS320C672x Floating-Point Digital Signal Processor ROM (Rev. C)
    PDF, 60 Кб, Версия: C, Файл опубликован: 25 сен 2006
    Describes the features of the C9230C100 TMS320C672x digital signal processor ROM. The system level patch, bootloader utilities and example code, can be downloaded from this link: http://www-s.ti.com/sc/psheets/sprc203/sprc203.zip.
  • TMS320C672x Power Consumption Summary (Rev. B)
    PDF, 55 Кб, Версия: B, Файл опубликован: 22 сен 2006
    This document discusses the power consumption of the Texas Instruments TMS320C672x digital signal processor (DSP). Power consumption on TMS320C67x™ devices is highly application-dependent. A spreadsheet is provided to model power consumption for the user’s application. To get good results from the spreadsheet, realistic usage parameters must be entered. The low-core voltage and other power d
  • Using ROM Contents on TMS320C672x
    PDF, 92 Кб, Файл опубликован: 5 фев 2008
    This application report explains how to configure an application based on pure software libraries and routines and how to properly use the provided ROM contents for the TMS320C672x DSP generation of devices. Several software examples are provided, explaining the process in progressive steps.
  • Using the TMS320C672x Bootloader (Rev. D)
    PDF, 456 Кб, Версия: D, Файл опубликован: 10 сен 2009
    This application report describes the design details of the TMS320C672x bootloader and describes a set of software utilities designed to facilitate formatting of application code for use with the bootloader.This application report contains a system level patch, the bootloader utilities and project code that can bedownloaded from this link:
  • Thermal Considerations for the DM64xx, DM64x, and C6000 Devices
    PDF, 127 Кб, Файл опубликован: 20 май 2007
    As integrated circuit (IC) components become more complex, the challenge of producing an end product with superior thermal performance increases. Thermal performance is a system level concern, impacted by IC packaging as well as by printed circuit board (PCB) design. This application report addresses the thermal considerations for the TMS320DM64xx, TMS320DM64x, and TMS320C6000в„ў DSP devices.
  • Common Object File Format (COFF)
    PDF, 125 Кб, Файл опубликован: 15 апр 2009
Серия: SMV320C6727B-SP (3)
  • Semiconductors > Space & High Reliability > Processor > Digital Signal Processor > C6000 DSPs
На английском языке: Datasheet Texas Instruments SMV320C6727BHFHM
