Datasheet Texas Instruments SN74CBT3257PWLE — Даташит
СерияSN74CBT3257
МодельSN74CBT3257PWLE
4-битный мультиплексор/демультиплексор на полевых транзисторах 1 из 2 16-TSSOP от -40 до 85
SN74CBT3257 datasheet
PDF, 1.4 Мб, Версия: M, Файл опубликован: 15 янв 2004
Микросхема Логический контроллер, Multiplexer/Demultiplexer Bus Switch 1Element CMOS 8IN 16Pin TSSOP T/R
SN74CBT3257PWLE
11 ₽
TradeElectronics
SN74CBT3257PWLE
SN74CBT3257PWLE
SN74CBT3257PWLE
Pin16
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Additional FeaturesLow Power
Approx. Price (US$)0.24 | 1ku
Bandwidth(Max)(MHz)200
Bits(#)4
Channels(#)4
F @ Nom Voltage(Max)(Mhz)200
ICC @ Nom Voltage(Max)(mA)0.003
Тип входаTTL/CMOS
Mux Configuration1:2
Operating Temperature Range(C)-40 to 85
Тип выходаTTL/CMOS
Package GroupTSSOP
Package Size: mm2:W x L (PKG)16TSSOP: 32 mm2: 6.4 x 5(TSSOP)
Ron(Max)(Ohms)7
Ron(Typ)(Ohms)5
Schmitt TriggerNo
Technology FamilyCBT
VCC(Max)(V)5.5
VCC(Min)(V)4
Voltage(Nom)(V)5
tpd @ Nom Voltage(Max)(ns)0.25
RoHSНе совместим
  • Flexible Voltage-Level Translation With CBT Family Devices
    PDF, 40 Кб, Файл опубликован: 20 июл 1999
    Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency.
  • 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
    The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not
  • 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)
    PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
  • VOLTAGE LEVEL TRANSLATION (SL) - Family
    PDF, 111 Кб, Файл опубликован: 21 сен 2011
  • Semiconductors > Switches and Multiplexers > Multiplexer/Demultiplexer (Mux/Demux) > Digital Mux/Demux
На английском языке: Datasheet Texas Instruments SN74CBT3257PWLE
