Datasheet Texas Instruments LM7705MM/NOPB — Даташит
СерияLM7705
МодельLM7705MM/NOPB
Малошумящий генератор отрицательного смещения 8-VSSOP от -40 до 125
LM7705 Low-Noise Negative Bias Generator datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 28 сен 2015
Package TypeDGK
Industry STD TermVSSOP
Package QTY1000
CarrierSMALL T&R
МаркировкаF26A
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
Iout(Max)0.026 A
Iq(Typ)0.078 мА
Package GroupVSSOP
Special FeaturesEnable
TopologyBuck/Boost
ТипCharge Pump
Vin(Max)5.25 В
Vin(Min)3 В
Vout(Max)-0.232 В
Vout(Min)-0.232 В
  • Evaluation Modules & Boards: LM7705MMEVAL
    Evaluation Board for the LM7705
  • Evaluation Modules & Boards: ADS7056EVM-PDK
    ADS7056 Ultra-Low-Power Ultra-Small-Size 14-Bit 2.5MSPS SAR ADC Performance Demonstration Kit (PDK)
  • Bridging the Divide: A DAC Applications Tutorial (Precision Signal Path)
    PDF, 1.9 Мб, Файл опубликован: 23 сен 2010
  • AN-1952 Designing with Thermocouples (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 7 май 2013
    In 1821 Thomas Seebeck discovered the physical phenomenon that when you join two dissimilar metalson both ends and heat one end, a continuous current is created in the thermoelectric circuit . If the otherend is broken, a voltage can be measured that is proportional to the temperature difference between theheated junction (measuring or hot junction) and the open end (reference or cold ju
  • Dual Bipolar Power-Supply Considerations for Amplifiers
    PDF, 427 Кб, Файл опубликован: 1 авг 2017
Серия: LM7705 (3)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost or Inverting Charge Pump (Inductorless)
На английском языке: Datasheet Texas Instruments LM7705MM/NOPB
