Datasheet Texas Instruments LM75AIMME/NOPB — Даташит
СерияLM75A
МодельLM75AIMME/NOPB
В±2В°C Industry Standard Temperature Sensor with I2C/SMBus Interface 8-VSSOP -55 to 125
LM75A Digital Temperature Sensor and Thermal Watchdog With Two-Wire Interface datasheet
PDF, 1.2 Мб, Версия: P, Файл опубликован: 30 дек 2014
Package TypeDGK
Industry STD TermVSSOP
Package QTY250
CarrierSMALL T&R
МаркировкаT00A
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
Addresses8
InterfaceI2C, SMBus, 2-Wire
Iq(Typ)280 uA
Local Sensor Accuracy(Max)2 +/- C
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Special FeaturesProgrammable Alert,Fault Queue
Supply Current(Max)500 uA
Supply Current(Typ)280 uA
Supply Voltage(Max)5.5 В
Supply Voltage(Min)2.7 В
Temp Resolution(Max)9 bits
  • Temperature sensors: PCB guidelines for surface mount devices (Rev. A)
    PDF, 5.6 Мб, Версия: A, Файл опубликован: 18 янв 2019
    Power hungry electronic components such as CPUs GPUs or FPGAs as well as voltage regulators heat up during operation. Some applications require ambient air temperature measurements while others need to measure the temperature of a nearby component on the PCB. Measuring ambient air temperature with a surface mount technology (SMT) device is challenging due to the thermal influence of other compo
  • Applying I2C-Compatible Temperature Sensors in Systems With Slow Clock Edges (Rev. A)
    PDF, 33 Кб, Версия: A, Файл опубликован: 6 май 2013
    This Application Note describes a method of interfacing a given microcontroller with a Texas Instruments digital temperature sensor.
  • Sensing and Monitoring for Control and Protection Seminar
    PDF, 245 Кб, Файл опубликован: 17 фев 2003
  • Tiny Temperature Sensors for Remote Systems
    PDF, 156 Кб, Файл опубликован: 17 фев 2003
  • AN-1155 A Simple Software I2C Routine for the COP8
    PDF, 121 Кб, Файл опубликован: 15 май 2004
    Application Note 1155 A Simple Software I2C Routine for the COP8
  • Semiconductors > Sensing Products > Temperature Sensors > Local Digital Temperature Sensors
На английском языке: Datasheet Texas Instruments LM75AIMME/NOPB
