Datasheet Texas Instruments 74AC11074PWLE — Даташит
Серия74AC11074
Модель74AC11074PWLE
Двойные триггеры D-типа с активацией по положительному фронту, с прозрачным и предустановленным 14-TSSOP от -40 до 85
Dual D-Type Positive-Edge-Triggered Flip-Flop With Clear And Preset datasheet
PDF, 667 Кб, Версия: A, Файл опубликован: 1 апр 1996
Pin14
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
3-State OutputNo
Approx. Price (US$)0.71 | 1ku
Bits(#)2
F @ Nom Voltage(Max)(Mhz)100
ICC @ Nom Voltage(Max)(mA)0.04
Тип входаCMOS
Operating Temperature Range(C)-40 to 85
Output Drive (IOL/IOH)(Max)(mA)24/-24
Тип выходаCMOS
Package GroupTSSOP
Schmitt TriggerNo
Technology FamilyAC
VCC(Max)(V)5.5
VCC(Min)(V)3
Voltage(Nom)(V)3.3
5
tpd @ Nom Voltage(Max)(ns)11.4
8.2
RoHSНе совместим
  • Live Insertion
  • Introduction to Logic
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
  • Semiconductors > Logic > Flip-Flop/Latch/Register > D-Type Flip-Flop
На английском языке: Datasheet Texas Instruments 74AC11074PWLE
