Datasheet Texas Instruments THS5651AIPW — Даташит
СерияTHS5651A
МодельTHS5651AIPW
10-битный цифро-аналоговый преобразователь (ЦАП) с быстродействием 125 MSPS 28-TSSOP от -40 до 85
10-Bit 125 MSPS CommsDAC datasheet
PDF, 948 Кб, Версия: A, Файл опубликован: 25 сен 2002
Pin28
Package TypePW
Industry STD TermTSSOP
Package QTY50
МаркировкаTJ5651A
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
АрхитектураCurrent Source
DAC Channels1
InterfaceParallel CMOS
Interpolation1x
Package GroupTSSOP
Package Size: mm2:W x L28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP) PKG
Power Consumption(Typ)175 mW
Разрешение10 Bits
SFDR61 дБ
Sample / Update Rate125 MSPS
  • Evaluation Modules & Boards: THS5651EVM
    THS5651A 10-Bit, 125-MSPS Digital-to-Analog Converter Evaluation Module
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200 Low-Cost Portable Power Supply Evaluation Module
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
  • Semiconductors > Data Converters > Digital-to-Analog Converters (DACs) > High Speed DACs (>10MSPS)
На английском языке: Datasheet Texas Instruments THS5651AIPW
