Datasheet Texas Instruments SN74LVC157AQDRQ1 — Даташит
СерияSN74LVC157A-Q1
МодельSN74LVC157AQDRQ1
Каталог автомобилей Четверной 2-линейный селектор данных/мультиплексор 16-SOIC от -40 до 125
Quadruple 2-Line to 1-Line Data Selector/Multiplexer datasheet
PDF, 787 Кб, Версия: C, Файл опубликован: 9 апр 2008
Pin16
Package TypeD
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
Approx. Price (US$)0.16 | 1ku
Bits(#)2
Channels(#)4
F @ Nom Voltage(Max)(Mhz)100
ICC @ Nom Voltage(Max)(mA)0.01
Тип входаTLL/CMOS
Operating Temperature Range(C)-40 to 125
Output Drive (IOL/IOH)(Max)(mA)24/-24
Тип выходаCMOS
Package Size: mm2:W x L (PKG)16SOIC: 59 mm2: 6 x 9.9(SOIC)
RatingAutomotive
Schmitt TriggerNo
Technology FamilyLVC
ТипStandard
VCC(Max)(V)3.6
VCC(Min)(V)2
Voltage(Nom)(V)2.7
3.3
tpd @ Nom Voltage(Max)(ns)8.2
7
RoHSНе совместим
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Specialty Logic > Decoder/Encoder/Multiplexer
На английском языке: Datasheet Texas Instruments SN74LVC157AQDRQ1
Публикации по теме
