Datasheet Texas Instruments LM723E/883 — Даташит
СерияLM723QML
МодельLM723E/883
Линейный регулятор военного уровня 150 мА с регулируемым выходом/LDO 20-LCCC от -55 до 125
LM723QML Voltage Regulator datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 22 апр 2013
Pin202020
Package TypeNAJNAJNAJ
Industry STD TermLCCCLCCCLCCC
JEDEC CodeS-CLCC-NS-CLCC-NS-CLCC-N
Package QTY505050
CarrierTUBETUBETUBE
Маркировка/883 Q >T/883 Q ACOLM723E
Width (мм)8.898.898.89
Length (мм)8.898.898.89
Thickness (мм)1.7531.7531.753
Pitch (мм)1.271.271.27
Max Height (мм)1.9051.9051.905
RoHSSee ti.com
  • Digital Designer's Guide to Linear Voltage Regulators & Thermal Mgmt (LDO) (Rev. A)
    PDF, 509 Кб, Версия: A, Файл опубликован: 4 июн 2008
  • AN-1148 Linear Regulators: Theory of Operation and Compensation (Rev. B)
    PDF, 300 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses the operation and compensation of linear regulators.
  • Understanding the Terms and Definitions of LDO Voltage Regulators
    PDF, 197 Кб, Файл опубликован: 21 окт 1999
    This report provides an understanding of the terms and definitions of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current standby current efficiency transient response line/load regulation power supply rejection output noise voltage accuracy and power dissipation. Each section includes an example to increase the understandab
  • Packaging Limits Range of Linear Regulators
    PDF, 75 Кб, Файл опубликован: 8 май 2010
    The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
Серия: LM723QML (4)
  • Semiconductors > Space & High Reliability > Power Management Products > Linear Regulators (LDO)
На английском языке: Datasheet Texas Instruments LM723E/883
