Datasheet Texas Instruments TMS320C203PZ — Даташит
СерияTMS320C203
МодельTMS320C203PZ
Цифровой сигнальный процессор 100-LQFP
Digital Signal Processors datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 30 авг 1998
Pin100
Package TypePZ
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Package QTY90
CarrierJEDEC TRAY (5+1)
МаркировкаTMS320C203PZ
Width (мм)14
Length (мм)14
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
  • Designing the TMS320C203 DSP Development Board for TMS320C203 Evaluation
    PDF, 479 Кб, Файл опубликован: 1 июл 1997
    This application brief describes the design of the TMS320C203 development board (DVB) from both the hardware and software approach. The DVB is a simple stand-alone application board used to evaluate the performance and characteristics of the TMS320C203 digital signal processor (DSP) hardware and software. The DVB contains the Texas Instruments (TI?) TMS320C203 DSP and provides full-speed ve
  • Implementing Circular Buffers With Bit-Reversed Addressing
    PDF, 84 Кб, Файл опубликован: 1 июл 1997
    Delay lines are used in many DSP applications. Delay lines provide a buffer of the last N samples of data for a filter or other algorithm. While delay lines can be implemented as linear or circular buffers, buffers of the circular variety are often preferred due to their relative simplicity.Texas Instruments' (TI) TMS320 family of DSPs can manipulate circular buffer pointers without penalty to
  • Interfacing the TLC5618A Digital-to-Analog Converter to the TMS320C203 DSP
    PDF, 107 Кб, Файл опубликован: 11 май 1998
    This application report describes the hardware and software needed to interface the TLC5618A dual 12-bit digital-to-analog converter (DAC) to the TMS320C203 digital signal processor (DSP). The solution presented provides the bridge between the system digital signals and the analog signal processing. The software organization and flow chart are presented with the software listing.
  • Interfacing the TLC5510 Analog-to-Digital Converter to the TMS320C203 DSP
    PDF, 401 Кб, Файл опубликован: 27 апр 2000
    This application report is a summary of the application note titled Interfacing the TLC5510 Analog-to-Digital Converter to the TMS320C203 DSP (literature number SLAA029) that presents guidelines for interfacing the TI TLC5510 analog-to-digital converter (ADC) to the TI TMS320C203 DSP. The TLC5510 is a CMOS, 8-bit, 20 MSPS (megasamples per second) ADC utilizing a semi-flash architecture. The TLC551
    PDF, 540 Кб, Файл опубликован: 1 фев 1998
    This application report presents guidelines for interfacing the Texas Instruments (TI(TM)) TLC5510 8-bit parallel-output analog-to-digital converter (ADC) to the TI TMS320C203 DSP data bus. The 8-bit ADC operates at a rate of 20 MHz. The C callable application program (assembly code) used to initialize the TMS320C203 and execute the code is also discussed.This report serves as reference inform
  • Interfacing the TLV1572 Analog-to-Digital Converter to the TMS320C203 DSP (Rev. B)
    PDF, 135 Кб, Версия: B, Файл опубликован: 11 май 1999
    This application report presents a hardware solution for interfacing the TLV1572 10-bit, 1.25 MSPS (Mega Samples Per Second), successive low-power analog-to-digital converter (ADC) to the TMS320C203 16-bit fixed-point digital signal processor (DSP). In addition, a C-callable interface program is shown which supports the data transfer between ADC and DSP.
  • Interfacing the TLV1544 Analog-to-Digital Converter to the TMS320C203 DSP (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 15 фев 1999
    This application report presents two hardware solutions for interfacing the TLV1544 10-bit low-power analog-to-digital converter (ADC) to the TMS320C203 16-bit fixed-point digital signal processor (DSP). The report describes the interface hardware and shows a C-callable software routine which supports the data transfer. In addition, it provides useful hints on the design of a typical system power
  • Semiconductors > Processors > Other Processors
На английском языке: Datasheet Texas Instruments TMS320C203PZ
