Линейка продуктов KEEN SIDE
Datasheet Texas Instruments 74CBTLV1G125DBVRQ1 — Даташит
СерияSN74CBTLV1G125-Q1
Модель74CBTLV1G125DBVRQ1
Автомобильный каталог Низковольтный переключатель шины с одним полевым транзистором 5-SOT-23 от -40 до 125
SN74CBTLV1G125-Q1 Low-Voltage Single FET Bus Switch datasheet
PDF, 704 Кб, Файл опубликован: 24 сен 2009
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY3000
МаркировкаVCTO
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Additional FeaturesPowered off protection
Полоса частот200 МГц
Configuration1:1 SPST
Input/Ouput Voltage(Max)3.6 В
Input/Output Continuous Current(Max)128 мА
Input/Output OFF-state Capacitance(Typ)7 пФ
Количество каналов1
OFF-state leakage current(Max)1 мкА
ON-state leakage current(Max)1 мкА
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
RatingAutomotive
Ron(Max)25 Ohms
Ron(Typ)5 Ohms
Supply Current(Max)10 uA
Supply Range3.6 Max
VIH(Min)2 В
VIL(Max)0.8 В
Vdd(Max)3.6 В
Vdd(Min)2.3 В
Vss(Max)N/A В
Vss(Min)N/A В
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: SN74CBTLV1G125-Q1 (1)
  • 74CBTLV1G125DBVRQ1
На английском языке: Datasheet Texas Instruments 74CBTLV1G125DBVRQ1
Публикации по теме
