Datasheet Texas Instruments THS5661AIPW — Даташит
СерияTHS5661A
МодельTHS5661AIPW
12-битный цифро-аналоговый преобразователь (ЦАП) с быстродействием 125 MSPS 28-TSSOP от -40 до 85
12-Bit, 125 MSPS, CommsDAC Digital-to-Analog Converter datasheet
PDF, 960 Кб, Версия: B, Файл опубликован: 25 сен 2002
Pin28
Package TypePW
Industry STD TermTSSOP
Package QTY50
МаркировкаTJ5661AI
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
АрхитектураCurrent Source
DAC Channels1
InterfaceParallel CMOS
Interpolation1x
Package GroupTSSOP
Package Size: mm2:W x L28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP) PKG
Power Consumption(Typ)175 mW
Разрешение12 Bits
SFDR59 дБ
Sample / Update Rate125 MSPS
  • Evaluation Modules & Boards: THS5661EVM
    THS5661A 12-Bit, 125-MSPS Digital-to-Analog Converter Evaluation Module
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200 Low-Cost Portable Power Supply Evaluation Module
  • Using TI FIFOs to Interface High-Speed Data Converters With TI TMS320 DSPs
    PDF, 249 Кб, Файл опубликован: 8 июн 2001
    Most high-speed data converters cannot be connected directly to a digital signal processor (DSP). The required transfer rates would tie up most of the DSP's I/O bandwidth. A FIFO is an appropriate solution for this problem because it can buffer a large block of data, and the DSP can read data from the FIFO in a burst mode. This is much more efficient compared to single reads for every sampled valu
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
Серия: THS5661A (3)
  • Semiconductors > Data Converters > Digital-to-Analog Converters (DACs) > High Speed DACs (>10MSPS)
На английском языке: Datasheet Texas Instruments THS5661AIPW
