Datasheet Texas Instruments LM43603QDSURQ1 — Даташит
Серия | LM43603-Q1 |
Модель | LM43603QDSURQ1 |
Automotive Qualified SIMPLE SWITCHERВ® 3.5V to 36V, 3A Synchronous Step-Down Voltage Converter 16-SON -40 to 125
LM43603-Q1 SIMPLE SWITCHERВ® 3.5-V to 36-V, 3-A Synchronous Step-Down Voltage Converter datasheet
PDF, 1.9 Мб, Версия: B, Файл опубликован: 21 апр 2017
Статус продукта | Анонсирован (Компонент анонсирован, но еще не запущен в серийное производство. Образцы могут быть как доступны, так и нет) |
Pin | 16 |
Package Type | DSU |
Package QTY | 3000 |
Width (мм) | 4 |
Length (мм) | 5 |
Thickness (мм) | .9 |
Mechanical Data | Скачать |
Approx. Price (US$) | 2.18 | 1ku |
Control Mode | Current Mode |
Duty Cycle(Max)(%) | 99 |
Iout(Max)(A) | 3 |
Iq(Typ)(mA) | 0.027 |
Operating Temperature Range(C) | -40 to 125 |
Package Group | SON |
Rating | Automotive |
Regulated Outputs(#) | 1 |
Special Features | Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification Tracking |
Switching Frequency(Max)(kHz) | 2200 |
Switching Frequency(Min)(kHz) | 200 |
Тип | Converter |
Vin(Max)(V) | 36 |
Vin(Min)(V) | 3.5 |
Vout(Max)(V) | 28 |
Vout(Min)(V) | 1 |
RoHS | TBD |
- Evaluation Modules & Boards: LM43603PWPEVM
LM43603PWP Synchronous Step-Down Converter Evaluation Module
- Inverting Applications Made SIMPLE With LM4600x and LM4360x (Rev. B)PDF, 1.9 Мб, Версия: B, Файл опубликован: 20 фев 2015
Weoftenrequirepowersourceswithnegativeoutputvoltages.Therearemanydifferentwaystoproduceanegativeoutputvoltagefromapositiveinputvoltage.Oneoptionisapolarity-invertingbuck-boostconverter.Theadvantagesofthistopologyarethatitrequireslowcomponentcountandthatitcanbebuiltwithstandardhigh-sideregulato - Thermal Design Made Simple With LM43603 and LM46002PDF, 535 Кб, Файл опубликован: 15 сен 2014
This Application Report will walk through the thermal design of power supplies using the LM43603 and LM46002.In the process we will cover common tips and approximations to speed up your design. - Compensation Made SIMPLE With LM4360x, LM4600xPDF, 457 Кб, Файл опубликован: 29 июл 2014
Compensating a DC-DC buck converter is challenging if the designer is not familiar with the loop control theory. To achieve a stable design under all corner and adverse conditions, the user must properly compensate the regulator. While DC-DC converters with external compensation provide flexibility, they increase complexity. The LM43600/1/2/3 and LM46000/1/2 are a family of Wide VIN, fully-synchro - Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x - AN-1197 Selecting Inductors for Buck Converters (Rev. B)PDF, 558 Кб, Версия: B, Файл опубликован: 23 апр 2013
Серия: LM43603-Q1 (6)
- LM43603AQPWPRQ1 LM43603AQPWPTQ1 LM43603QDSURQ1 LM43603QDSUTQ1 LM43603QPWPRQ1 LM43603QPWPTQ1
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
