Datasheet Texas Instruments 5962-9687802QEA — Даташит
СерияSN54366A
Модель5962-9687802QEA
Драйверы шестнадцатеричной шины с выходами с 3 состояниями 16-CDIP от -55 до 125
Datasheet
TSP
Hex Bus Drivers With 3-State Outputs 16-CDIP -55 to 125
5962-9687802QEA
5962-9687802QEA
Pin16
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Width (мм)6.92
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
RoHSНе совместим
  • Live Insertion
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
Серия: SN54366A (5)
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Buffer Drivers
59629687802QEA, 5962 9687802QEA
На английском языке: Datasheet Texas Instruments 5962-9687802QEA
