Datasheet Texas Instruments SN74AS760N — Даташит
| Серия | SN74AS760 |
| Модель | SN74AS760N |
Восьмеричные буферы/линейные драйверы с выходами с открытым коллектором 20-PDIP от 0 до 70
Octal Buffers & Line Drivers With Open-Collector Outputs datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 1 янв 1995
Купить SN74AS760N на РадиоЛоцман.Цены — от 114 до 1 703 ₽41 предложений от 21 поставщиков LOGIC GATES AND INVERTERS. Buffer, Non-Inverting 2 Element 4 Bit per Element Open Collector Output 20-SO. Logic - Buffers, Drivers, Receivers,... | |||
| SN74AS760NS Texas Instruments | 204 ₽ | ||
| SN74AS760N Texas Instruments | от 1 703 ₽ | ||
| SN74AS760NS Texas Instruments | по запросу | ||
| SN74AS760NE4 Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | N |
| Industry STD Term | PDIP |
| JEDEC Code | R-PDIP-T |
| Package QTY | 20 |
| Carrier | TUBE |
| Маркировка | SN74AS760N |
| Width (мм) | 6.35 |
| Length (мм) | 24.33 |
| Thickness (мм) | 4.57 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| Bits | 8 |
| F @ Nom Voltage(Max) | 125 Mhz |
| ICC @ Nom Voltage(Max) | 0.019 мА |
| Рабочий диапазон температур | от 0 до 70 C |
| Output Drive (IOL/IOH)(Max) | - /64 мА |
| Package Group | PDIP |
| Package Size: mm2:W x L | See datasheet (PDIP) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | AS |
| VCC(Max) | 5.5 В |
| VCC(Min) | 4.5 В |
| Voltage(Nom) | 5 В |
| tpd @ Nom Voltage(Max) | 18.5 нс |
| Бессвинцовая технология (Pb Free) | Да |
- Advanced Schottky Load ManagementPDF, 277 Кб, Файл опубликован: 1 фев 1997
Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme - Advanced Schottky (ALS and AS) Logic FamiliesPDF, 1.9 Мб, Файл опубликован: 1 авг 1995
Серия: SN74AS760 (6)
- SN74AS760DW SN74AS760DWG4 SN74AS760DWR SN74AS760N SN74AS760N3 SN74AS760NSR
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
