Datasheet Texas Instruments OPA2604AU/2K5E4 — Даташит
СерияOPA2604
МодельOPA2604AU/2K5E4
Операционный усилитель с двумя входами на полевых транзисторах, с низкими искажениями, 8-SOIC, от -40 до 85
OPA2604 Dual FET-Input, Low-Distortion Operational Amplifier datasheet
PDF, 572 Кб, Версия: A, Файл опубликован: 9 апр 2015
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
Маркировка2604AUOPA
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Additional FeaturesBurr-Brownв„ў Audio
АрхитектураFET
CMRR(Min)80 дБ
CMRR(Typ)100 дБ
GBW(Typ)20 МГц
Input Bias Current(Max)1000 pA
Iq per channel(Max)6 мА
Iq per channel(Typ)5.25 мА
Количество каналов2
Offset Drift(Typ)8 uV/C
Output Current(Typ)35 мА
Rail-to-RailNo
Slew Rate(Typ)25 V/us
Total Supply Voltage(Max)48 +5V=5, +/-5V=10
Total Supply Voltage(Min)9 +5V=5, +/-5V=10
Vn at 1kHz(Typ)11 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)5 мВ
  • Stabilizing difference amplifiers for headphone applications
    PDF, 670 Кб, Файл опубликован: 28 апр 2015
  • Distortion and source impedance in JFET-input op amps
    PDF, 182 Кб, Файл опубликован: 24 окт 2014
  • Double The Output Current To A Load With The Dual OPA2604 Audio Op Amp
    PDF, 21 Кб, Файл опубликован: 27 сен 2000
    Headphones typically have an impedance of 40О© to 300О©. By using the dual OPA2604 and four resistors one can economically drive a 2.8V peak signal into the 40О© headphones.
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
  • Reducing distortion from CMOS analog switches
    PDF, 375 Кб, Файл опубликован: 29 янв 2015
На английском языке: Datasheet Texas Instruments OPA2604AU/2K5E4
