Datasheet Texas Instruments TPS54622RHLT — Даташит
СерияTPS54622
МодельTPS54622RHLT
Синхронный понижающий преобразователь SWIFT™ с входным напряжением от 4,5 до 17 В, ток 6 А, с защитой от сбоев 14-VQFN от -40 до 150
TPS54622 4.5-V to 17-V Input, 6-A Synchronous Step-Down SWIFTв„ў Converter With Hiccup Protection datasheet
PDF, 1.7 Мб, Версия: E, Файл опубликован: 22 дек 2016
Pin14
Package TypeRHL
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
Маркировка54622
Width (мм)3.5
Length (мм)3.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Control ModeCurrent Mode
Duty Cycle(Max)98 %
Iout(Max)6 A
Iq(Typ)0.6 мА
Рабочий диапазон температурот -40 до 150 C
Package GroupVQFN
Regulated Outputs1
Special FeaturesEnable,Frequency Synchronization,Power Good,Pre-Bias Start-Up,Synchronous Rectification,Tracking
Switching Frequency(Max)1600 kHz
Switching Frequency(Min)200 kHz
ТипConverter
Vin(Max)17 В
Vin(Min)4.5 В
Vout(Max)15 В
Vout(Min)0.6 В
  • Evaluation Modules & Boards: TPS54622EVM-012
    Evaluation Module for TPS54622 Synchronous Step Down SWIFTВ™ Converter
  • Calculating Efficiency
    PDF, 175 Кб, Файл опубликован: 19 фев 2010
    This application report provides a step-by-step procedure for calculating buck converter efficiency and power dissipation at operating points not provided by the data sheet.
  • Designing Type III Compensation for Current Mode Step-Down Converters (Rev. A)
    PDF, 298 Кб, Версия: A, Файл опубликован: 15 сен 2010
    One of the well-known benefits of current-mode control is that the system stability can be easily achieved by Type II compensation design. It is possible to improve the transient response of a current mode DC/DC converter by adopting Type III compensation to boost the crossover frequency and phase margin. Type III compensation is simple to design and needs only one extra component.
  • Understanding Thermal Dissipation and Design of a Heatsink
    PDF, 59 Кб, Файл опубликован: 4 май 2011
    Power dissipation performance must be well understood prior to integrating devices on a printed-circuit board (PCB) to ensure that any given device is operated within its defined temperature limits. When a device is running, it consumes electrical energy that is transformed into heat. Most of the heat is typically generated by switching devices like MOSFETs, ICs, etc. This application report discu
Серия: TPS54622 (3)
На английском языке: Datasheet Texas Instruments TPS54622RHLT
