Datasheet Texas Instruments SN74AUC1G06DBVRE4 — Даташит
СерияSN74AUC1G06
МодельSN74AUC1G06DBVRE4
Одиночный буфер/драйвер инвертора с выходом с открытым стоком 5-SOT-23 от -40 до 85
Single Inverter Buffer/Driver With Open-Drain Output datasheet
PDF, 991 Кб, Версия: M, Файл опубликован: 2 фев 2007
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY3000
МаркировкаU06R
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
3-State OutputNo
Bits1
F @ Nom Voltage(Max)250 Mhz
Gate TypeOPEN DRAIN INVERTER BUFFER
ICC @ Nom Voltage(Max)0.01 мА
LogicInverting
Output Drive (IOL/IOH)(Max)9/-9 мА
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Schmitt TriggerNo
Special FeaturesIOFF,low power consumption,low tpd
Sub-FamilyInverting Buffer/Driver
Technology FamilyAUC
VCC(Max)2.7 В
VCC(Min)0.8 В
Voltage(Nom)0.8,1.2,1.5,1.8,2.5 В
tpd @ Nom Voltage(Max)5,3.1,2.4,2.5,1.7 нс
  • Application of the Texas Instruments AUC Sub-1-V Little Logic Devices (Rev. A)
    PDF, 449 Кб, Версия: A, Файл опубликован: 19 сен 2002
    Power consumption and speed are always concerns in electronic system logic design. Texas Instruments (TI) announces the industry?s first sub-1-V logic family that provides significant benefits to portable consumer electronics by operating at low power and high speed, while maintaining overall system signal integrity. TI?s next-generation logic family is the advanced ultra-low-voltage CMOS (AUC) fa
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74AUC1G06DBVRE4
