Datasheet Texas Instruments UC3910DTRG4 — Даташит
СерияUC3910
МодельUC3910DTRG4
4-битный ЦАП и монитор напряжения 16-SOIC от 0 до 70
Datasheet
TSP
Опорный чип напряжения, 4Bit DAC and Voltage Monitor 16-SOIC 0 to 70
UC3910DTRG4
135 ₽
UC3910DTRG4
UC3910DTRG4
UC3910DTRG4
Pin16
Package TypeD
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
RoHSНе совместим
  • U-158 The UC3910 Combines Programmability, Accuracy and Integrated Functions
    PDF, 491 Кб, Файл опубликован: 5 сен 1999
    As high-performance processors continue to develop, their respective power-supply requirements become more stringent, often requiring low, custom voltages and increasingly tighter regulation. Intel's Pentium(r)Pro power-system specification, for instance, demonstrates the need for tight regulation, programmable power-supply voltage, and programmable voltage monitoring for status reporting to the p
  • U-157 Fueling the Megaprocessor - A DC/DC Converter Design
    PDF, 678 Кб, Файл опубликован: 5 сен 1999
    This application note provides a detailed account of design tradeoffs and procedures for the development of a voltage regulator module (VRM) for the Intel Pentium (r)Pro processor. This voltage regulator features Unitrode's UC3886 Average Current Mode PWM Controller and UC3910 4-BIT DAC and Voltage Monitor ICs configured in a buck regulator. Test results and waveforms show how the VRM power supply
Серия: UC3910 (4)
На английском языке: Datasheet Texas Instruments UC3910DTRG4
