Datasheet Texas Instruments TMS320DM6441ZWT — Даташит
СерияTMS320DM6441
МодельTMS320DM6441ZWT
Цифровая медиасистема DaVinci на кристалле 361-NFBGA
TMS320DM6441 Digital Media System-on-Chip datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 30 авг 2010
Pin361361361
Package TypeZWTZWTZWT
Industry STD TermNFBGANFBGANFBGA
JEDEC CodeS-PBGA-NS-PBGA-NS-PBGA-N
МаркировкаDAVINCIDM6441ZWTTMS320
Width (мм)161616
Length (мм)161616
Thickness (мм).9.9.9
Pitch (мм).8.8.8
Max Height (мм)1.41.41.4
RoHSНе совместим
    XDS200 USB Debug Probe
  • De-Interlacing and YUV 4:2:2 to 4:2:0 Conversion on DM6446 Using the Resizer (Rev. B)
    PDF, 186 Кб, Версия: B, Файл опубликован: 17 дек 2008
    Video signals captured directly from charge-coupled device (CCD) cameras naturally have interlaced effects and are in a 4:2:2 interleaved format. They typically need to be converted to a 4:2:0 planar format before being encoded because most video compression standards accept input only in 4:2:0 format. It is better to reduce or remove the interlaced artifacts in the original video signal when fe
  • Creating a TMS320DM6446 Audio Encode Example Using XDC Tools (Rev. A)
    PDF, 130 Кб, Версия: A, Файл опубликован: 26 фев 2008
    This application report describes how to create an eXpressDSPв„ў Algorithm for Digital Media (XDM) compatible audio encode example on the TMS320DM6446 processor using the eXpressDSP Components (XDC) tool. XDM is an extension of TI eXpress DSP Algorithm Interface Standard (xDAIS).The example consists of:The LinuxВ® application code running on the ARM side of DM6446The d
  • Booting DaVinci EVM from NAND Flash (Rev. A)
    PDF, 3.4 Мб, Версия: A, Файл опубликован: 15 дек 2008
    Currently, the DaVinciв„ў evaluation module (DVEVM) supports three boot modes: the DVEVM can boot from NOR (default), NAND, or universal asynchronous receiver/transmitter (UART). NOR Flash offers the advantages of one-byte random access and execute-in-place technology. NAND Flash is not as easy to work with since it requires Flash Translation Layer (FTL) software to make it accessible; however
  • Implementing the DDR2 PCB Layout on the TMS320DM644x DMSoC (Rev. G)
    PDF, 154 Кб, Версия: G, Файл опубликован: 16 июн 2008
    This application report contains implementation instructions for the DDR2 interface contained on the TMS320DM644x digital signal processor (DSP) device. The approach to specifying interface timing for the DDR2 interface is quite different than on previous devices.The previous approach specified device timing in terms of data sheet specifications and simulation models. The system designer was
  • TMS320DM644x ROM Migration Guide
    PDF, 47 Кб, Файл опубликован: 20 июл 2010
    This application report describes ROM bootloader (RBL) differences between silicon revision 2.1 and 2.3 of the TMS320DM644x Digital Media System-on-Chip (DMSoC).
  • Fast Development with DaVinci On Screen Display (OSD)
    PDF, 414 Кб, Файл опубликован: 6 июл 2006
    While On Screen Display (OSD) functionality became prevalent as a cheaper alternative to using buttons/knobs to control television settings, in today's society, it seems like everyday a new gadget comes out which uses OSDs.Imagine a video phone or set-top application for a minute; both of these applications require video overlaid with some graphics OSD, and may require some blending between v
  • TMS320DM6446/3 Power Consumption Summary (Rev. B)
    PDF, 66 Кб, Версия: B, Файл опубликован: 16 авг 2010
    This document discusses the power consumption of the Texas Instruments TMS320DM6446 and TMS320DM6443 digital media System-on-Chip (DMSoC). Power consumption on the DM6446/3 devices is highly application-dependent, so spreadsheets are provided to model power consumption for a user's application. To get good results from the spreadsheet, realistic usage parameters must be entered. The low-core volta
  • Booting and Flashing via the DaVinci TMS320DM644x Serial Interface (Rev. A)
    PDF, 159 Кб, Версия: A, Файл опубликован: 10 сен 2009
    This application report describes two related pieces of software that are used together to boot the ARM core of the DM644x via the universal asynchronous receiver/transmitter (UART0) serial interface. Additionally, this software allows you to write the needed files to a NAND or NOR flash device, connected to the DM644x AEMIF, such that the ARM core can boot from these external memories. The softwa
  • Decode Demo for the DaVinci DVEVM/DVSDK 1.2 (Rev. A)
    PDF, 335 Кб, Версия: A, Файл опубликован: 27 июн 2007
  • Encode Demo for the DaVinci DVEVM/DVSDK 1.2 (Rev. A)
    PDF, 323 Кб, Версия: A, Файл опубликован: 27 июн 2007
  • TMS320DM6441 Power Consumption Summary Application Report
    PDF, 101 Кб, Файл опубликован: 8 апр 2008
    This document discusses the power consumption of the Texas Instruments TMS320DM6441 digital media System-on-Chip (DMSoC). Power consumption on the DM6441 device is highly application-dependent, so a spreadsheet is provided to model power consumption for a user’s application. To get good results from the spreadsheet, realistic usage parameters must be entered. The low-core voltage and other power d
  • Basic Application Loading over the Serial Interface for the DaVinci TMS320DM644x
    PDF, 219 Кб, Файл опубликован: 21 дек 2006
    This application report describes two related pieces of software that are used together to download an application over the DM644x UART0 serial interface and run it out of the ARM internal memory. The discussion begins with a description of a host application that executes on a user’s PC, and includes a description of how to interface to the ROM boot loader of the DM644x device. The discussion of
  • EncodeDecode Demo for the DaVinci DVEVM/DVSDK 1.2 (Rev. A)
    PDF, 282 Кб, Версия: A, Файл опубликован: 27 июн 2007
  • EDMA v3.0 (EDMA3) Migration Guide for TMS320DM644x DMSoC
    PDF, 243 Кб, Файл опубликован: 3 дек 2005
    This Document describes migrating from the Texas Instruments TMS320C64x digital signal processor (DSP) enhanced direct memory access (EDMA2) to the TMS320DM644x Digital Media System-on-Chip (DMSoC) EDMA3. This document summarizes the key differences between the EDMA3 and the EDMA2 and provides guidance for migrating from EDMA2 to EDMA3.
  • USB Compliance Checklist (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 10 мар 2010
  • DaVinci Technology Background and Specifications (Rev. A)
    PDF, 108 Кб, Версия: A, Файл опубликован: 4 янв 2007
  • Understanding the Davinci Resizer (Rev. B)
    PDF, 469 Кб, Версия: B, Файл опубликован: 17 июл 2008
    The image-scaling operation is one of the most commonly used video and imaging processing functions. The resizer hardware module in the DaVinciв„ў video processing subsystem (VPSS) provides the scaling capability in hardware, therefore off-loading the system for other processing tasks. To achieve good video quality while maintaining good overall system performance, a better understanding of th
  • Understanding the Davinci Preview Engine (Rev. A)
    PDF, 209 Кб, Версия: A, Файл опубликован: 23 июл 2008
    The Preview Engine block in the DaVinci video processing sub-system (VPSS) provides some critical functions for image and video processing. These functions, if implemented in software, require a significant number of computations in terms of million instructions per second (MIPs). By offloading these functions, the valuable MIPs can be used for more differentiating tasks, such as video compression
  • Building a Small Embedded Linux Kernel Example (Rev. A)
    PDF, 1.3 Мб, Версия: A, Файл опубликован: 27 май 2008
    Building a Small Embedded Linux Kernel Example Application Report
  • 5 VIN solution using DCDC Controllers, a LDO, and a Digitally Prog. Sequencer
    PDF, 179 Кб, Файл опубликован: 24 ноя 2008
  • LSP 2.10 DaVinci Linux Drivers (Rev. A)
    PDF, 1.2 Мб, Версия: A, Файл опубликован: 8 июл 2009
  • EDMA v2.0 to EDMA v3.0 (EDMA3) Migration Guide (Rev. A)
    PDF, 292 Кб, Версия: A, Файл опубликован: 21 авг 2008
    This application report summarizes the key differences between the enhanced direct memory access (EDMA3) used on C64x+в„ў DSP devices and the EDMA2 used on TMS320C64xв„ў DSP devices, and provides guidance for migrating from EDMA2 to EDMA3.
  • TMS320C64x to TMS320C64x+ CPU Migration Guide (Rev. A)
    PDF, 310 Кб, Версия: A, Файл опубликован: 20 окт 2005
    This document describes migration from the Texas Instruments TMS320C64xв„ў digital signal processor (DSP) to the TMS320C64x+в„ў DSP. The objective of this document is to indicate differences between the two cores and to briefly describe new features. Functionality in the devices that is identical is not included. For detailed information about either device, see the TMS320C64x/C64x+ DSP
  • Understanding TI's PCB Routing Rule-Based DDR Timing Specification (Rev. A)
    PDF, 93 Кб, Версия: A, Файл опубликован: 17 июл 2008
    This application report motivates the way the DDR high-speed timing requirements are now going to be communicated to system designers. The traditional method of using data sheet parameters and simulation models is tedious. The system designer uses this information to evaluate whether timing specifications are met and can be expected to operate reliably.Ultimately, the real question the hardwa
  • Common Object File Format (COFF)
    PDF, 125 Кб, Файл опубликован: 15 апр 2009
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
  • Semiconductors > Processors > Digital Signal Processors > Media Processors > Digital Video Processors
На английском языке: Datasheet Texas Instruments TMS320DM6441ZWT
