Линейка продуктов KEEN SIDE
Datasheet Texas Instruments LM89-1DIMM/NOPB — Даташит
СерияLM89
МодельLM89-1DIMM/NOPB
В±0.75В°C Remote and Local Temperature Sensor with SMBus Interface 8-VSSOP 0 to 125
LM89 В±0.75В°C Accurate, Remote Diode And Local Digital Temperature Sensor With Two-Wire Interface datasheet
PDF, 1.3 Мб, Версия: D, Файл опубликован: 23 июн 2014
Package TypeDGK
Industry STD TermVSSOP
Package QTY1000
МаркировкаT19D
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
InterfaceI2C,SMBus
Local Sensor Accuracy(Max)3 +/- C
Рабочий диапазон температурот 0 до 125 C
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Remote Channel1
Remote Diode Temp Range for Listed Accuracy80 C
Remote Sensor Accuracy(Max)0.75 +/- C
Remote Sensor CorrectionOffset Correction Register
Remote Temp Resolution(Max)11 bits
Special FeaturesProgrammable Alert,Programmable conversion rate,Shutdown
Supply Current(Typ)800 uA
Supply Voltage(Max)3.6 В
Supply Voltage(Min)3 В
Temp Resolution(Max)8 bits
  • Semiconductors > Sensing Products > Temperature Sensors > Remote / Multi-channel Temperature Sensors
LM891DIMM/NOPB, LM89 1DIMM/NOPB
На английском языке: Datasheet Texas Instruments LM89-1DIMM/NOPB
