Datasheet Texas Instruments TLC2654C-14D — Даташит
СерияTLC2654
МодельTLC2654C-14D
Малошумящий операционный усилитель со стабилизацией прерывателем 14-SOIC
Advanced LinCMOS Low-Noise Chopper Stabilized Operational Amplifiers datasheet
PDF, 1.2 Мб, Версия: G, Файл опубликован: 25 апр 2001
Элитан
TLC2654C-14D
678 ₽
TLC2654C-14D
TLC2654C-14D
Pin14
Package TypeD
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Additional FeaturesZero Drift
Approx. Price (US$)1.78 | 1ku
АрхитектураCMOS
CMRR(Min)(dB)105
CMRR(Typ)(dB)125
GBW(Typ)(MHz)1.9
Input Bias Current(Max)(pA)60
Iq per channel(Max)(mA)2.4
Iq per channel(Typ)(mA)1.5
Number of Channels(#)1
Offset Drift(Typ)(uV/C)0.01
Operating Temperature Range(C)-40 to 85
0 to 70
Output Current(Typ)(mA)3
Rail-to-RailIn to V-
Out
Slew Rate(Typ)(V/us)2.8
Total Supply Voltage(Max)(+5V=5, +/-5V=10)16
Total Supply Voltage(Min)(+5V=5, +/-5V=10)4.6
Vn at 1kHz(Typ)(nV/rtHz)23
Vos (Offset Voltage @ 25C)(Max)(mV)0.02
RoHSНе совместим
  • Choosing an ADC and Op Amp for Minimum Offset
    PDF, 72 Кб, Файл опубликован: 28 окт 1999
    Designing a mixed-signal circuit containing analog and digital components can be a challenge to the development engineer. Requirements such as a low single-polarity supply voltage and a high degree of precision may conflict, and make the choice of components and the best circuit design difficult. This report discusses problems that arise in using operational amplifiers (op amps) for signal conditi
  • DC Parameters: Input Offset Voltage
    PDF, 295 Кб, Файл опубликован: 27 мар 2001
    The input offset voltage, VIO, is a common dc parameter in operational amplifier (op amp) specifications. This report aims to familiarize the engineer by discussing the basics and modern aspects of VIO by providing a definition and a detailed explaination of causes of VIO for BJT, BiFET, and CMOS devices. Discussion centers around measurement techniques, data sheet specifications, and the effect o
TLC2654C14D, TLC2654C 14D
На английском языке: Datasheet Texas Instruments TLC2654C-14D
