Datasheet Texas Instruments TPS78625KTT — Даташит
СерияTPS786
МодельTPS78625KTT
Сверхмалошумящие, быстрые, ВЧ, 1,5 А, с низким падением напряжения, линейные стабилизаторы с высоким PSRR, 5-DDPAK/TO-263 от -40 до 125
TPS786 Ultralow-Noise, High-PSRR, Fast, RF, 1.5-A Low-Dropout Linear Regulators datasheet
PDF, 1.4 Мб, Версия: M, Файл опубликован: 30 сен 2015
Pin5
Package TypeKTT
Industry STD TermTO-263
JEDEC CodeR-PSFM-G
Width (мм)8.42
Length (мм)10.16
Thickness (мм)4.58
Pitch (мм)1.7
Max Height (мм)4.83
Accuracy(%)2
Additional FeaturesEnable
Overcurrent Protection
Thermal Shutdown
Approx. Price (US$)1.34 | 1ku
Fixed Output Options(V)1.8
2.5
2.8
3
3.3
Iout(Max)(A)1.5
Iq(Typ)(mA)0.26
Noise(uVrms)48
Operating Temperature Range(C)-40 to 125
Output Capacitor TypeCeramic
Output OptionsAdjustable Output
Fixed Output
PSRR @ 100KHz(dB)32
Package GroupDDPAK/TO-263
Package Size: mm2:W x L (PKG)See datasheet (SON)
Regulated Outputs(#)1
Vdo(Typ)(mV)390
Vin(Max)(V)5.5
Vin(Min)(V)2.7
Vout(Max)(V)5.2
Vout(Min)(V)1.22
RoHSНе совместим
  • Evaluation Modules & Boards: TPS78601DRBEVM
    Evaluation Module for TPS78601 Single Output LDO
  • Evaluation Modules & Boards: XILINXPWR-079
    XILINXPWR-079 Power Management Evaluation Module for Xilinx FPGAs
  • Evaluation Modules & Boards: DEM-SOT223LDO
    DEM-SOT223LDO Compatible with Most Positive Output LDOs in SOT223 (DCQ) Package
  • Using Thermal Calculation Tools for Analog Components
    PDF, 1.1 Мб, Файл опубликован: 2 сен 2010
    This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o
На английском языке: Datasheet Texas Instruments TPS78625KTT
