Datasheet Texas Instruments LM20145QMH/NOPB — Даташит
СерияLM20145-Q1
МодельLM20145QMH/NOPB
Автомобильный класс 2,95–5,5 В, 5 А, синхронный понижающий стабилизатор тока с регулируемой частотой 16-HTSSOP от -40 до 125
PowerWise Adj Freq Sync Buck Reg datasheet
PDF, 1.4 Мб, Версия: E, Файл опубликован: 27 мар 2013
IC REG BUCK ADJ 5A 16HTSSOP. Buck Switching Regulator IC Positive Adjustable 0.8V 1 Output 5A 16-PowerTSSOP (0.173', 4.40mm Width). PMIC...
LM20145QMH/NOPB
78 ₽
Xinhuo Future
LM20145QMH/NOPB
260 ₽
LM20145QMH/NOPB
350 ₽
LM20145QMH/NOPB
Pin1616
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9292
CarrierTUBETUBE
Маркировка20145QMH
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Control ModeCurrent Mode
Duty Cycle(Max)85 %
Iout(Max)5 A
Iq(Typ)3.5 мА
Package GroupHTSSOP
RatingAutomotive
Regulated Outputs1
Special FeaturesEnable,Power Good,Pre-Bias Start-Up,Synchronous Rectification,Tracking
Switching Frequency(Max)750 kHz
Switching Frequency(Min)250 kHz
ТипConverter
Vin(Max)5.5 В
Vin(Min)2.95 В
Vout(Max)5 В
Vout(Min)0.8 В
  • Evaluation Modules & Boards: LM20145EVAL
    5A, PowerWiseВ® Adjustable Frequency Synchronous Buck Regulator Evaluation Module
  • AN-2077 LM20k POL Module (Rev. A)
    PDF, 1.3 Мб, Версия: A, Файл опубликован: 3 май 2013
    The LM20k is a full-featured synchronous buck switching regulator capable of driving up to 6A of loadcurrent and converting an input voltage between 2.95V and 5.5V down to an output voltage as low as0.8V. Fault protection features include cycle-by-cycle current limit, output power good, and output overvoltageprotection. The dual function soft-start/tracking pin can be used to control the sta
  • Powering FPGAs Using LM201xx PowerWise Synchronous Buck Regulators (Rev. A)
    PDF, 45 Кб, Версия: A, Файл опубликован: 3 май 2013
    The LM201xx family offers a full range of features and options enabling a FPGA designer to fullycustomize their power solution to meet the system application needs.
  • AN-1752 5A LM20k Reference Designs (Rev. C)
    PDF, 161 Кб, Версия: C, Файл опубликован: 3 май 2013
    This application note discusses the design options using the high performance 5A synchronous buckconverters LM20125 and LM20145.
Серия: LM20145-Q1 (3)
На английском языке: Datasheet Texas Instruments LM20145QMH/NOPB
Публикации по теме
