Datasheet Texas Instruments THS4121IDG4 — Даташит
СерияTHS4121
МодельTHS4121IDG4
Полностью дифференциальный КМОП-усилитель 8-SOIC, 3,3 В, 100 МГц, 43 В/мкс, от -40 до 85
THS4120, THS4121: High-Speed Fully Differential-I/O Amplifier datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 13 окт 2004
Package TypeD
Package QTY75
Маркировка4121I
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
2nd Harmonic79 dBc
3rd Harmonic93 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураCMOS,Fully Differential,Voltage FB
BW @ Acl100 МГц
CMRR(Min)64 дБ
CMRR(Typ)96 дБ
GBW(Typ)100 МГц
Input Bias Current(Max)1.2 pA
Iq per channel(Max)13.5 мА
Iq per channel(Typ)11 мА
Количество каналов1
Offset Drift(Typ)25 uV/C
Output Current(Typ)25 мА
Rail-to-RailIn to V+,Out
Slew Rate(Typ)55 V/us
Total Supply Voltage(Max)3.5 +5V=5, +/-5V=10
Total Supply Voltage(Min)3 +5V=5, +/-5V=10
Vn at 1kHz(Typ)16 нВ/rtГц
Vn at Flatband(Typ)5.4 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)8 мВ
  • Evaluation Modules & Boards: THS4140EVM
    THS4140EVM Evaluation Module
  • Fully-Differential Amplifiers (Rev. E)
    PDF, 867 Кб, Версия: E, Файл опубликован: 19 сен 2016
    Differential signaling has been commonly used in audio, data transmission, and telephone systems for many years because of its inherent resistance to external noise sources. Today, differential signaling is becoming popular in high-speed data acquisition, where the ADC’s inputs are differential and a differential amplifier is needed to properly drive them.Two other advantages of di
  • High-Voltage Signal Conditioning for Differential ADCs
    PDF, 125 Кб, Файл опубликован: 14 июн 2004
    Analog designers are frequently required to convert high-voltage signals to levels acceptable to low-voltage data converters with differential inputs. This paper describes solutions for this common task using modern amplifiers and typical power supplies. Three examples of conditioning В±10V bipolar signals for low-voltage analog-to-digital converters (ADCs) are shown: a single-supply design,
На английском языке: Datasheet Texas Instruments THS4121IDG4
