Datasheet Texas Instruments TPS40131RHBT — Даташит
СерияTPS40131
МодельTPS40131RHBT
Двухфазный синхронный понижающий контроллер со встроенными драйверами МОП-транзисторов 32-VQFN от -40 до 85
Two-Phase Synchronous Buck Controller w/Integrated MOSFET Drivers datasheet
PDF, 1.2 Мб, Файл опубликован: 12 фев 2007
Pin3232
Package TypeRHBRHB
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY250250
CarrierSMALL T&RSMALL T&R
Маркировка40131TPS
Width (мм)55
Length (мм)55
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
Control ModeCurrent Mode
Duty Cycle(Max)87.5 %
Iout(Max)50 A
Iq(Typ)1 мА
Number of Phases2
Package GroupVQFN
Regulated Outputs2
Special FeaturesEnable,Frequency Synchronization,Phase Interleaving,Power Good,Pre-Bias Start-Up,Remote Sense,Synchronous Rectification
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)100 kHz
ТипController
Vin(Max)40 В
Vin(Min)1 В
Vout(Max)5.8 В
Vout(Min)0.7 В
  • Evaluation Modules & Boards: TPS40131EVM
    TPS40131 Evaluation Module
  • TMS320C6472 5V Input Pwr Design, Integrated FET DC/DC Converters and Controllers
    PDF, 452 Кб, Файл опубликован: 26 мар 2010
    This reference design is intended for designers who wish to design up to eight TMS320C6472 Digital Signal Processors into a system using a nominal input voltage of 5 V, with a flexible design using external FETs, and low-dropout regulators for the low-power rails.
  • 'C6472 12Vin Flexible Pwr Design Using DCDC Controllers and LDOs (8x C6472)
    PDF, 441 Кб, Файл опубликован: 26 мар 2010
    This reference design is intended for designers who wish to design up to eight TMS320C6472 Digital Signal Processors into a system using a nominal input voltage of 12 V, external FETs for design flexibility, and low-dropout regulators for the low-power rails.
Серия: TPS40131 (3)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
На английском языке: Datasheet Texas Instruments TPS40131RHBT
